TractorLinks.com
Show Parts for Model:
Re: 930 at her first job
John LaBoyteaux
11-18-2012 15:35:49
Hello Case Nutty,
Since you seem to be one of the main CASE guys on this site perhaps you can help with this question. The 3pt arms would not raise on my 1030 so we removed and cleaned the control valve. Now they will raise but not stay up unless the engine is revved up.
Before we tear into it again, any idea the most likely problem?
John
Case Nutty 1660
11-18-2012 16:12:50
 Re: 930 at her first job in reply to John LaBoyteaux, 11-18-2012 15:35:49
I would check the valve over again as I would think you have a valve seating problem still, do you have access to a Case service manual? they go into detail on how to test/repair the DOM valve, I am assumeing your remote valve works correctly? if the DOM valve checks out fine then my next thought would be you have a rockshaft seal problem, I have seen them crack the piston sleeve/ and or blow the seals due to the 3pt not cancelling, hope this gives you a few ideas to check out cnt
John LaBoyteaux
11-18-2012 21:28:33
 Re: 930 at her first job in reply to Case Nutty 1660, 11-18-2012 16:12:50
We have only the ITT manuel, will need to look for original CASE manuel.
John
