TractorLinks.com
Show Parts for Model:
Re: 1070 case trans problem in wi.
1370rod
11-15-2012 22:09:02
Steve, usually a bad P Shift will have some small amount of movement in one of the shifts. Having nothing is strange unless the torq limiter is burned out from slippage or hub damage. If the P Shift is making a grinding or rattleling noise indicating plantatary damage that can cost alot to repair. Otherwise if you can fix it your self a couple grand can go a long ways if there is no plant. damage. Do a complete hyd and press. test on the tractor before you start. Never know, it might not be so bad. Rod.
