TractorLinks.com
Show Parts for Model:
Re: Lets see your plowing tractors
Jason Kozlowski
11-15-2012 07:42:15
1967 Case 841LP with a 4-16 Case 200 series two-way plow.
1968 Case 530 with a 1955 2-14 Case T-series two way plow
1968 Case 530 with a two bottom David Brown Plow.
grandpajohn
11-15-2012 08:13:07
 Re: Lets see your plowing tractors in reply to Jason Kozlowski, 11-15-2012 07:42:15
That two plow sure takes a lot of front weights to hold the tractor down.
Jason Kozlowski
11-15-2012 12:18:28
 Re: Lets see your plowing tractors in reply to grandpajohn, 11-15-2012 08:13:07
There are nine weights on the front of that 830, plus the starter weight, for a total of 938 lbs. The manual says ten is the limit, I was afraid to mount all ten for fear I might crack the housing. With the plow raised, the tractor was still light in the front. You could bring up the front end if you were too quick with the clutch. I have since added a full set of cover boards to the plow, so it weighs close to 2,000 lbs now. She pulled it fine, it's just a lot of weight back there.
