What to do????
Eldo case
I have a 211b case tractor that is smoking very bad. I put in a set of rings years ago. I am thinking about a complete rebuild and can't decide on what sleeve set to use. The 126 cid set is almost impossible to find and just almost as high. I have been thinking about having the block bored for the 148 sleeves but that is not stock for a 200b but will be cheaper in the long run. Just don't know what to do? Open to your all suggestions. Thanks!
Nobody will tear your engine apart to nit pick the originality of it. Another option is to have your sleeves sleeved and reuse the old pistons with new rings, done that too.
Eldo,
Make it a bear in sheep clothing. I don't see a problem making it a 300B under a 200B hood. The trannies are the same, so no issues there.
Loren
Hi, I have a few good used parts for a 211b should you need something give me a call. Thanks Jim --No-Advertising-in-Forums
