800 caseomatic temp guage
good luck
Been fiddling with Cases for a while now and have NEVER seen a working COM temp gage or NOS or a replica/replacement.
Put in a low temp water temp sender and idiot light on mine but don't pull much so it should never get very hot. Thought about a reg temp gage.
Luck Seems to be low, also having trouble with the radiator on this tractor been through four different ones and still not 100%. I cant figure out why no one is making a new radiator for these along with the 730 and 830 early low profiles. bad deal what are you supposed to do.
i kept a spare rad from one of my parts tractors just for this reason. think you may be able to get an early 730 rad to fit in there but may not be able to put the door back on. IF its a show tractor you won't be able to do it. could also change front top hood with an early 7/830 hood. Try Don Livingston.
A GOOD rad shop should be able to recore them. Probably $500+ (my 730 one was quoted at $400 about 5 years ago but copper has gone up I think).
