SC Case Wheel Wedges
tomfg
Regarding the 12 wheel wedges on each wheel on my SC Case, do the wedges with the long tang go on the inside of the rim, or outside?
Looking at the rim, it would look like it doesn't matter. I can't tell looking on the IHC/Case diagram.
Thanks, Tom
I am assuming that you have the spoked wheel centers. The long tang is the wedge that stretches the rim outward, the flat wheel-wedges with the short tang just act like stops. The outside edge of the wheel center is flat, so it doesn't matter which way you put them on. However, you will probably want to put all of the long-tanged locks on the outside (whether you dish-in or dish-out) so that you can easily remove and reinstall the rims.
