TractorLinks.com
Show Parts for Model:
1959 800 caseomatic
gene watkins
11-06-2012 13:28:15
replaced fluid and filter on auto trans. put gages on pump and power clutch. no reading at any rpm. this tractor did not run when bought. does run good now. had bad trans leak fixed that. ,
Adirondack case guy
11-06-2012 14:27:31
 Re: 1959 800 caseomatic in reply to gene watkins, 11-06-2012 13:28:15
Gene,
You can easily pull the cover/ pump mtg assy. from the side of the torque tube, The pump,relief valve, drive gear and all connecting porting (O rings etc) will be totally visable to you. so you can inspect it. Beyond that you have the valve assy that you can also inspect quite easily.
Loren
