Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Case SC to Pull
[Return to Forum]
Cliff S
11-05-2012 18:33:06
64.136.26.153
Anyone Put Larger than Stock Pistons in a SC To Make a Puller?
If So How Large of Pistons?
Thinking about 4"Piston and this would make 201cid!
With Tin Wheeles and Light Weighted Will it Make 3500lbs with a 180lb Driver?
I know these tractors are a Bit Weak on Power for Pulling Compaired to a DC But I have a SC with 3 5/8 Pistons making 40 Hp and its a work tractor!
Because i grew up on a SC I wanted to make a Puller out of Non Running SC
that I have verry little Invested in to Join my VAC and my Farmalls that i pull and Be Differnt than the Average Puller!
Thanks for any help with my SC!
Cliff S
[Reply]   [No Email]
DeereSkin
11-08-2012 14:42:46
174.59.25.4
Re: Case SC to Pull in reply to Cliff S, 11-05-2012 18:33:06
CLIFF S
On the SC, I have always heard that the SC was similar to the Farmall H in that the "power to weight ratio". Of all your Farmalls, do you have an H that you pull with? I know that you mentioned the C.
Now on to this VAC Hybrid everyone is talking about. You say 15mph in the 6500lb. Class? "C'Mon Man"!!! I've got a 4010 that has a hard time doing that!!!!
  [Reply]  [No Email]
Cliff S
11-08-2012 16:50:47
64.136.26.153
Re: Case SC to Pull in reply to DeereSkin, 11-08-2012 14:42:46
I have a H I pull in Top Cut Classes and it dose well in 4000 and 4500!
The VA Last Summer at Tioga Co,Pa Fair the Track as Hard as a Rock with a Pro Drop Pan sled that was our Speed!
We where 2nd in 5500 and 6500 Small tire Open (15.5x38 tire Limit)
On a Verry Soft Track a Month ago we went up to 13 mph at Buffalo Vally but in 4500 (2nd to a Case 300)and 5700 (1st)
Where not the Fastest Small Case
Thats Brad Peters Case 300 But Where Competitive with Him Most of the Time!
I was on the VA when it Won a 6250lbs 6 Mph $200 to win Class at Trout Run with a Class of JD G s,Oliver 88 s and a Case DC 4
The VA is a Good Puller But Theres Allways Room for Inprovement and It could use some 16.9x38 at some Tracks and another 20 HP But It all Takes Time!!
Iam Just Glad to Share Seat Time on it and Leave the Expences up to the Owner!
Cliff S
  [Reply]  [No Email]
Wounded Deere
11-07-2012 10:06:44
71.245.10.176
Cliff, Don't you have a good Case puller? A Vac with an eagle with teeth on the side panels (well at least it has a Vac hood and grill) , I saw you win down in Harrisburg, That was a pretty heavy class for that sized tractor, im not sure I agree with Pa puller knows, I think Cases are a pretty good pulling tractor, I know they have beaten me a lot of times
  [Reply]  [No Email]
Cliff S
11-07-2012 13:07:42
64.136.26.151
Re: Case SC to Pull in reply to Wounded Deere, 11-07-2012 10:06:44
Yes that was Me Winning the 6250 6 Mph Class at the Mid Alantic Super Pull on what started out as a Case VA Thats More of a Open Class Tractor thats Capable of Running up to 15+ Mph 6500lbs Class on a Drop Pan Sled and a Hard Track!
But thats a Friends Tractor that I share Seat Time On!
I Have A VAC Of my Own with 36 Rubber on the Back thats Done Ok for its Self But at 3.5 MPH Class!
Like Ive said I Have IH Pullers Also thats Done Well But the SC that Ive Been thinkin of Building would be Just a Noncut 3.5 mph puller for Home and to Give People something to Ponder about!
I Think Almost any Tractor Can be Competitive if Enough Time is Spent on it Getting things Right!
I Spent Time Growing up on a SC and i am shure there like a DC/CC for Balance But Need More Power and if Kept under 5000lbs in Noncut at Home Pulls they Could Be Competive Puller!
Cliff S
  [Reply]  [No Email]
C. Amick
11-06-2012 19:00:58
138.210.9.42
Pistons of 3-11/16" diameter were the largest after market sleeves made for the SC. I like my SC's, but wouldn't be my choice for a puller. Too much weight to horsepower ratio. I would like to have a Case CC puller.
  [Reply]  [No Email]
Pa puller knows
11-06-2012 18:12:11
72.95.47.80
Stick to your IH!!!!
  [Reply]  [No Email]
Pa puller knows
11-07-2012 03:31:29
72.95.47.80
Re: Case SC to Pull in reply to Pa puller knows, 11-06-2012 18:12:11
What I meant to say is that you should put some more money and time in your IH "pullers" and try to make something out of them instead of another project!
  [Reply]  [No Email]
Cliff S
11-07-2012 12:42:11
64.136.26.151
Re: Case SC to Pull in reply to Pa puller knows, 11-07-2012 03:31:29
PA Puller
All 11 of my tractors that I Heve Pulled to a Point Championship somewhere Including my 40Hp SC Case!
And at this Time My Farmall Super C is The Current Points Leader in NATPA 3250 Div 3 and 2nd in 3500 Div 3 for the 2012 /2013 Season!
So I think Ive Done OK!
I just Thought it Would be Something Differnt than the Run of the Mill that Every Elese Pulls!
Cliff S
  [Reply]  [No Email]
Pa puller knows
11-08-2012 07:31:10
72.95.47.80
Re: Case SC to Pull in reply to Cliff S, 11-07-2012 12:42:11
Big whoop! You travel all that distance and spend that money to pull against 2-3 tractors in your class and then brag about it! You only go to local pulls that you think you might win! Like I said, why don't you spend money and concentrate on one tractor and have something than have six or more average pullers!
  [Reply]  [No Email]
Cliff S
11-08-2012 13:37:08
64.136.26.154
Re: Case SC to Pull in reply to Pa puller knows, 11-08-2012 07:31:10
To the Guy that Talks Big Without Puting up his Name
My Average Pullers only Won 8 out of 11 Point Championships at our Local Pulls Agenst Average up Twice My Hp Tractors that are our Local Pulls this Past year As You Well Know!
And One was Just a Spare Parts Tractor!
Lord forbid if I where to Improve Them!
My Compition Would Need to Spend Many More Thousands to Compete with My Average Pullers at there Pro Engine and Chassey Builders!
Good thing i Do my Own Work it Keeps the Cost Down!
Cliff S
  [Reply]  [No Email]
Cliff S
11-08-2012 13:09:46
64.136.26.154
No Differnt Than you and Your Tractors!
How Far do yo travel to get any Compition?
Atleast to our aera 140 miles away!
Most of the Guys you Pull agenst Should Pull in the Stock Class instesd of beenin 50ft+ Behind you in the 5/6 mph or Open Classes But if they Did You would Pull By Yourself!
And i Remember My Su C giving you More than its Share of Compition in the Div 3 3.5 mph Class this Year!
You Can Pull the 200 Now in 2T So Take it and To Wauseon and See for Yourself what Those Few Tractors Have For You in 3500 4000!
Then Agian Maby You Shouldnt Its Tough there
and your Spider
Gears may End up in the Scrap Pile!
Cliff S
  [Reply]  [No Email]
JohnDY
11-08-2012 05:12:00
99.149.231.64
Looks like you are doing pretty darn good with them tractors. I'm not much into building motors but if you have the time and parts I say go for it. Like you say its going to be local so have at it!!!!
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
