Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Case 1070, metal in oil pan
[Return to Forum]
Mitch K
11-04-2012 19:50:52
174.126.89.29
Looking for some advice. I bought a Case 1070 this summer with about 8100 hours. When I changed the oil, I found some metal in the bottom of the drain pan. The largest piece was about 1/8"; it looks like bearing metal. I also think there is a slight knock coming from the back of the engine when warm and idling. I don't hear anything unusual under load, but the old girl makes quite a racket anyway, and I don't know what's normal. The tractor didn't come with any maintenance records.
The question is: Do I tear into the engine now, or wait until I have an indication of something really wrong.
If I do dig into the engine, can I get at all the bearings and remove the crankshaft with the engine in the frame?
Thanks,
Mitch
[Reply]   [No Email]
dboll
11-06-2012 05:46:06
209.23.168.133
Re: Case 1070, metal in oil pan in reply to Mitch K, 11-04-2012 19:50:52
and you are still running it? sounds like the damage is already done, sounds like you spun a rod or main, better figure on pulling the crank and grinding it if it's a spun rod if it's a spun main you have a really big project
  [Reply]  [No Email]
j hikemper
11-05-2012 06:19:11
50.102.24.72
ohhhscht,!, shut it down. NOW!!!
  [Reply]  [No Email]
Mitch K
11-05-2012 05:37:21
174.126.89.29
Thanks Gentlemen,
Not what I wanted to hear, but what I expected. Snow is coming soon, and I don't have a shop.
Mitch
  [Reply]  [No Email]
John Saeli
11-05-2012 03:56:00
66.66.16.240
You DO have something terribly wrong!! Take it apart now. Like the others have said, bearings can be "rolled" in with the crank in place. However, if the crank is damaged, the tractor will need to be split to remove the crank for repair. Good luck.
  [Reply]  [No Email]
El Toro
11-05-2012 03:42:02
108.3.143.30
Drop the oil pan and take a look at the bearings. If you're finding metal you may have a spun bearing. You probably need to pull the engine. Have your local auto machine shop to check the crankshaft to see if it can be ground undersize. That engine may need a complete rebuild with that many hours. Hal
  [Reply]  [No Email]
casenut1
11-04-2012 20:33:52
107.8.39.45
pull the pan off. check the crank to see if it is serviceable. the bearings can be rolled out and in
with roll pins. might need over size bearings.
  [Reply]  [No Email]
casecollectorsc
11-04-2012 20:18:44
75.102.175.110
Best take the pan off and check before you do any more damage. Engine needs to come out to get crank out. Split at bellhousing and front bolster off.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
