TractorLinks.com
Show Parts for Model:
Re: diesel case 630 flywheel ring gear
Friedell Hinton@kywirefox
11-04-2012 18:32:10
If ring gear will come off you can turn it over if teeth are not at an angle, if at an angle about a half turn from where it is now and put back on. or you can unbolt the fly wheel an put back on at 2 or 3 bolt holes from where it was.
If this works I would put new starter drive on starter also Hope this will work for you.
windhillfarmer
11-05-2012 05:37:27
 Re: diesel case 630 flywheel ring gear in reply to Friedell Hinton@kywirefox, 11-04-2012 18:32:10
if the ends of my teeth on ring gear are ground down turning flywheel wont fix it that is if ground on the side thanks anyway
