TractorLinks.com
Show Parts for Model:
Re: Put the turbo on my 570
dflippin08
11-04-2012 16:23:50
If I had rotated it 90 degrees the inlet would have been too close to the fuel tank, unless i wouldve made a sadle for the turbo like you did. I dont have much exhaust pipe to support. Its only gona have a straight pipe with a 90 and a rain cap. The way i did it I didnt have to cut my intake or exhaust manifold, but my bent up hood will get a new hole. I will only using the tractor for work. There is 3 1/2 inches between the hood and the turbo, so I could still run it ouf the original hood hole if i wanted. Sometime in the next 2 weeks ill get it back on the dyno to see what the numbers look like.
Adirondack case guy.
11-04-2012 17:00:53
 Re: Put the turbo on my 570 in reply to dflippin08, 11-04-2012 16:23:50
I wasn't trying to knock your legs out from under you. I'm an old fart, forgot that the 530/70s had much larger fuel tanks: As I said, it will work well. Please post pics of the finished project, I'm sure you will be more than satisfied with the performance.
Loren
j hikemper
11-05-2012 06:23:52
 Re: Put the turbo on my 570 in reply to Adirondack case guy., 11-04-2012 17:00:53
GREAT WORK !!...if any of you gurus find another turbo i have a candidate for the next upgrade..
830man
11-04-2012 16:42:56
I would like to see the numbers it puts out. Any pump work?
dflippin08
11-04-2012 16:55:50
 Re: Put the turbo on my 570 in reply to 830man, 11-04-2012 16:42:56
I havent done anything to the pump, but someone has. It turns 2400 at wot. I dont know if anything else has been done or not. Ive gota get the egt on it first.
