Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Case Nutty
Erik ks farmer
11-04-2012 14:06:04
Thanks, my 554 is a silage baler, been to the dealer twice and tried lots of adjustments. It also has 18k bales on it. I may look at the 505 I would also like the 5 ft pickup.
504BalerGuy
11-05-2012 14:22:10
 Re: Case Nutty in reply to Erik ks farmer, 11-04-2012 14:06:04
With 18K bales my guess is your pickup teeth are shot. The teeth do a lot of work to get the bale started. The ones at tractor supply are junk. I know 1st hand. If you are going to do the work get the Vermeer teeth.
It is easier to start bales with a 5' baler. Just because it is a larger openning. It is harder to make a square shoulder 5' bale because sometime there is not enough hay to have a 5' windrow, and then you need to weave.
The later XL's were slowed down to reduce front buildup in light hay. The I baler will be spinning faster than a late model. Speeding the baler back up will help start bales better, you just might have more front buildup in light hay.
Dale in nw wa.
11-04-2012 17:52:06
I have a Geil 1600 and it will not start a bale when the hay is to dry or if it is way two wet.
