up date on c case
Anonymous-0
will got the top off trans and looks like the pulley shaff splins are wore bad and in side of gear now to get the pulley off and get shaff out and gears and see about getting it fix some how need all the help and addvice i can get jerry
I hate to tell you this, but you have a major project ahead of you. You will need to split the tractor between the clutch housing and the transmission case. You need 2 lineup pins 3/4" by 16 inches long to replace the 2 shouldered bolts; this makes realigning the 2 sections easier.
Call me a (406) 454-8758 if you have questions.
