Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 730 rim removal
11-04-2012 06:43:00
but how do you break the bead with the tire on the tractor? to break beads i lay the tire flat on the groun then carefully push down with the teeth on my backhoe bucket right close to the rim all the way around.
Jim McVay
11-05-2012 06:41:14
 Re: 730 rim removal in reply to gusbratz, 11-04-2012 06:43:00
I bring home the hydralic air powered bead breaker and push it right off. Only $1000 for one. We do our own tires on 30,000 acres farm in South Florida.
Adirondack case guy
11-04-2012 08:24:15
There are two simple and inexpensive ways to break the tire beads, while still on the tractor. You can buy a sliding hammer bead breaker or even cheaper, most Tractor Supply stores offer a chisel shaped tool that you hit with a 4# hammer that you drive inbetween the rim flange and tire bead. Both have a rounded blade about 3" wide and about 1/2" thick. I believe that KD Tools makes them both. They are handy and in expensive. I have used the Backho Bead breaker also, but that can damage the sidwall of the tire because you can't get the bh tooth to wedge in between the rim bead and tire bead like the bead breakers I described. I'm too old to bull rear wheels and tires around, so I look for the easiest way, with a minimal amount pulling, tugging and swearing.
