Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: DC Hydraulics
Case Nutty 1660
11-03-2012 20:00:48
can't quite see the LH connections but looks to be hooked up right, next question the fitting you changed was it the bottom LH that is hooked to the cylinder? and if so are you sure you have the spring/ball check installed correctly? here is another scan from the SM cnt
1952DC
11-03-2012 20:29:12
 Re: DC Hydraulics in reply to Case Nutty 1660, 11-03-2012 20:00:48
I changed out the TOP LH fitting from a scraped DC. Going to drain it and remove the Bottom left fitting in the morning to check spring and ball inside. Has to be the whole problem I believe. The ball is not sealing off the lift pressure. Good enough place to start.
Case Nutty 1660
11-03-2012 20:36:43
 Re: DC Hydraulics in reply to 1952DC, 11-03-2012 20:29:12
I can scan you info from the SM if you need it let me know what area you need if any cnt
1952DC
11-03-2012 20:43:35
 Re: DC Hydraulics in reply to Case Nutty 1660, 11-03-2012 20:36:43
Thanks for your help cnt. I am grateful. I would like to stay in touch. Tod
