New to me tractor
I am now the new owner of a 59 210B. It seem to run pretty good, but i did run into a problem today. The tractor just randomly cut off and then would only run on full choke. I cut it off and it started up and ran fine with no choke for a while. Im thinking there is a dirty filter and tank. Also, the loader hydraulics are very sluggish. The tractor has the correct amount of hydro fluid according to the stick. Im not sure where i should start, so any help would be great.
We will need more detail on sluggish hydraulics. If you have a model 21 loader with single acting lift cylinders, they can get air in them. To cure this lift the loader up afoot or two and loosen the small plug on the top of the lift cyl till oil seeps to the threads. this will help the loader to start lifting sooner. Barry.
When i want the loader to go up. I may hold on the lever for five to ten seconds before it will start moving. And, when going all the way up it starts really hesitating the higher it gets. I have a 21 loader. Can you be more specific on the bleeder screw. Thanks, Jeremy
Look for a small plug on the front transmission cover. It will have a dipstick attached to it. Clean around it and unscrew it to check the oil level. It should be at the high mark. Do you have single acting cylinders or double acting lift cylinders on the lifting arms.
