TractorLinks.com
Show Parts for Model:
Re: DC Hydraulics
1952DC
11-03-2012 17:30:53
Where do I find that adjuster? If it is a screw with a lock nut set up like I have seen in a photo from the operators manual I do not have anything like that on any of the 4 swivel 90* fittings. 2 on each side of the hyd. housing. The fitting I changed out is the TOP one to the drivers left side. If it was yours, what would your plan be for the morning? Where do I look? Thanks or all your responses and for putting up with my rookie questions.
Case Nutty 1660
11-03-2012 17:53:16
 Re: DC Hydraulics in reply to 1952DC, 11-03-2012 17:30:53
here is a scan from the service manual that may help identify the problem cnt
1952DC
11-03-2012 18:08:02
 Re: DC Hydraulics in reply to Case Nutty 1660, 11-03-2012 17:53:16
CNT that cylinder speed adjuster does not appear on my new tractor. I really do not need the hitch to work for anything I plan to do with this tractor, Is this speed adjuster necessary to the operation of my hitch? As I said before it went up just doesnt come back down.. Thank you.
Case Nutty 1660
11-03-2012 18:27:14
 Re: DC Hydraulics in reply to 1952DC, 11-03-2012 18:08:02
no it is not required to work a lot of them have been changed out over the years for a std swivel, are you sure you did not cross hook a line when reassembling? just a thought, maybe post us a pic and tell us the step/repairs you made maybe we can figuare out what happened cnt
1952DC
11-03-2012 19:42:26
 Re: DC Hydraulics in reply to Case Nutty 1660, 11-03-2012 18:27:14
Photos from the garage,,,
casecollectorsc
11-03-2012 21:37:11
 Re: DC Hydraulics in reply to 1952DC, 11-03-2012 19:42:26
RIGHT HAND SIDE top hose should go into filter for return and bottom right side is remote coupler. Top hoses have to be for hitch circuit and bottom for remote!!
casecollectorsc
11-03-2012 21:41:52
 Re: DC Hydraulics in reply to casecollectorsc, 11-03-2012 21:37:11
My mistake! You do have the circuits hooked up correct!! Picture wasn't quite clear, but I see it now. Must have missing ball and spring.
Case Nutty 1660
11-03-2012 20:00:48
can't quite see the LH connections but looks to be hooked up right, next question the fitting you changed was it the bottom LH that is hooked to the cylinder? and if so are you sure you have the spring/ball check installed correctly? here is another scan from the SM cnt
1952DC
11-03-2012 20:29:12
 Re: DC Hydraulics in reply to Case Nutty 1660, 11-03-2012 20:00:48
I changed out the TOP LH fitting from a scraped DC. Going to drain it and remove the Bottom left fitting in the morning to check spring and ball inside. Has to be the whole problem I believe. The ball is not sealing off the lift pressure. Good enough place to start.
Case Nutty 1660
11-03-2012 20:36:43
 Re: DC Hydraulics in reply to 1952DC, 11-03-2012 20:29:12
I can scan you info from the SM if you need it let me know what area you need if any cnt
1952DC
11-03-2012 20:43:35
 Re: DC Hydraulics in reply to Case Nutty 1660, 11-03-2012 20:36:43
Thanks for your help cnt. I am grateful. I would like to stay in touch. Tod
1952DC
11-03-2012 18:36:19
Photos are what I should of done in the first place..Going outside now for photos.. Please check back in on me, I can't thank you enough.
