Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
c case 1929
jerry m 3
11-03-2012 14:04:08
need to pull rear wheels any good ideas as to how jerry
jerry m3
11-04-2012 03:02:41
 Re: c case 1929 in reply to jerry m 3, 11-03-2012 14:04:08
thanks everyone for the advice will give it a try jerry
theljam
11-03-2012 23:32:00
Jack up the wheel you want to remove and block the tractor so it's safe. You will find two drilled and tapped 3/4" holes in the hub on each side of the axle. Make sure the holes are clean by running a tap through them. Next you need to drill two 3/4"+ holes in a heavy piece of steel about 2" thick spaced the same distance apart as the holes in the hub. Remove the cotter pin and castle nut that holds the hub on the axle. Place the piece of steel with that two holes flat against the end of the axle and thread two 3/4" bolts through the drilled holes and into the holes in the hub. Tighten the two bolts tight and hit the steel plate with a sledge hammer in the middle where it meets the axle on the other side. The wheel and hub should break loose from the axle. If not try tightening the bolt some more and hitting it again. The axle is tapered and has a key, if it has never been off it may take some serious tightening of the bolts to get it to pop loose. Good luck.
E. Schoen
11-03-2012 22:04:41
I have heard of loosining the nuts up then driving the tractor around in figure 8's. That is if the tractor runs!
