TractorLinks.com
Show Parts for Model:
DC weight
Jim McVay
11-02-2012 16:27:20
What will it weigh?
j hikemper
11-02-2012 17:05:08
 Re: DC weight in reply to Jim McVay, 11-02-2012 16:27:20
did the fromt tires/wheels come from a vac?
Jim McVay
11-02-2012 17:13:21
 Re: DC weight in reply to j hikemper, 11-02-2012 17:05:08
yes with 3/8" plate adapters
Case Nutty 1660
11-02-2012 17:07:10
had not looked that close good eye cnt
Case Nutty 1660
11-02-2012 16:32:14
4500-5500lbs?? cnt
Jim McVay
11-02-2012 16:56:00
 Re: DC weight in reply to Case Nutty 1660, 11-02-2012 16:32:14
I was hoping for 4250 or less. If you look through the rear wheels you can see the flat back "EAGLE" cover. It weighed I think 4600 with the old cast rear wheels.
Case Nutty 1660
11-02-2012 17:06:22
 Re: DC weight in reply to Jim McVay, 11-02-2012 16:56:00
jim my book shows 4100lbs for a CC on full steel so I was just guessing did you remove the pto and every thing else you could? the cast fronts add quite a bit but I can see you wanting them for front weight cnt
dboll
11-02-2012 20:27:05
 Re: DC weight in reply to Case Nutty 1660, 11-02-2012 17:06:22
a CC won't weigh 4100 on steel, our 40 dc with weight brackets, starter, batt,pto, 15.5-38 tires on spoked wheels weighs 4100
dboll
11-02-2012 20:27:51
 Re: DC weight in reply to dboll, 11-02-2012 20:27:05
that's with driver included
Jim McVay
11-02-2012 17:16:44
Yes all PTO removed. Rear cover has the big eagle on it. Will install weiht bracket on front with slab weiht flat if I can for 4500# class with me on it. Me at 230.
