Case 930 diesel wheatland
plow hand
Looking at a 930 ran 1 as a kid for a summer don't remember to much (30 years ago)..Is there anything to be aware of on this model that could be costly in the long run? thanks in advance..
a 930 wheatland is as dependable as they get, hyd. are simple easy to get to ,no power shift to go out , no turbo , low rpm engine run forever, keep her tranny full of oil ,dont get her to hot, she will last forever , ive had mine15 yrs, on a drag box , no trouble,mine is a 6 speed hand cluch. going to plow day sat with a 4 bottom ,i will try to post pictures next wk tom
Tom,thanks... the hand clutch is on the right?..I'm going to look at the pictures sent to me closer I prefer the foot clutch..again thanks
If it has the modified 377 block in it DON'T get it hot too many times or the center head will warp enough to start leaking. Usually leaks into the cylinders not outside of block. Otherwise an old power horse.
Rugged tractors. Easy on fuel. Start good in cold weather. We love ours.
Ours are foot clutch. Left side hand clutch perfect for when you're turned half rearward watching the chopper.
I'd like to have a dozen of 'em.
Glenn F.
