TractorLinks.com
Show Parts for Model:
IPTO Clutch for 1967 Case 430 Farm Tractor
Travwm
10-29-2012 16:37:30
Hi Everybody, I am trying to adjust the IPTO Clutch on a Case Model 430. I can't get it to release. The spring loaded pin does not seem to push in correctly in order to release the clutch adjustment plate to turn for the adjustment. Any ideas, or diagrams from a factory manual that could help me? Clymers Manual doesn't address it very well.
Thanks much!
Trav
Travwm
10-30-2012 05:55:35
 Re: IPTO Clutch for 1967 Case 430 Farm Tractor in reply to Travwm, 10-29-2012 16:37:30
You are correct. This one has no pins to pull. It has one round pin that is spring loaded, pushes in to release from the scalloped washer.
It should push in with little effort but does not.
A good parts diagram would be helpful.
Thanks,
Trav
Case Nutty 1660
10-30-2012 06:30:00
 Re: IPTO Clutch for 1967 Case 430 Farm Tractor in reply to Travwm, 10-30-2012 05:55:35
this is a breakdown from the service manual cnt
Joe Young
10-30-2012 09:13:28
 Re: IPTO Clutch for 1967 Case 430 Farm Tractor in reply to Case Nutty 1660, 10-30-2012 06:30:00
Same diagram from the parts manual....
Travwm
10-30-2012 13:27:24
 Re: IPTO Clutch for 1967 Case 430 Farm Tractor in reply to Joe Young, 10-30-2012 09:13:28
Thanks Joe,
Would you have the parts list to go along with this?
Thanks,
Trav
mEl
10-30-2012 03:40:54
You have the late PTO with the flat pin and scalloped washer if I am correct, I would not know why the button will not push in to release the washer. Is there pressure on it by any chance? Did you try putting something against it and gently tapping it. That PTO unit was the last of those series and if I am correct it has NO pins to pull, just push the button and turn the pto till it snaps back out in the scalloped washer. I wonder if someone has the capability of posting a pic of that unit?.
mEl
Case Nutty 1660
10-30-2012 04:51:12
 Re: IPTO Clutch for 1967 Case 430 Farm Tractor in reply to mEl, 10-30-2012 03:40:54
mEl here is the adjustment procedure if you think a parts breakdown would be helpful I can do that also, my other info was incorrect as I was thinking these had two lock pins like the big brother tractors I do know the last time I adjusted one it took a bit to get the adjustment to turn hope this helps a little cnt
casecollectorsc
10-29-2012 18:12:15
You pull the pin out and turn the collar and the other pin will drop in to lock it . Repeat until you have it correct.
Case Nutty 1660
10-29-2012 17:37:55
did you try both pins? one is always locked one is not gives a finer adjust that way cnt
