Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
case 1961 630 diesel
windhillfarmer
10-29-2012 05:25:39
i split the tractor to find out why the starter was grinding it looked like the starer gear was out all the way and it turned engine 1/2 revaluation then was spinning on ring gear i think i need to replace both starter gear and ring gear, i figured id check out the clutch because the bearing was in backwards and the spines on pressure plate were worn bad so i need 10" 1,1/2" 24 spine pressure plate, and a 10" 10 spine 1,1/8" clutch i looked over internet cant find there all 11" with bigger shaft thanks for the help
Klyde
10-29-2012 11:30:08
 Re: case 1961 630 diesel in reply to windhillfarmer, 10-29-2012 05:25:39
Bearing goes against the fork, not the fingers on the pressure plate. Get ahold of John Saeli (315 585 9826) for the parts he"ll fix you up.
j hikemper
10-29-2012 05:30:10
google ky clutch ,,, they ship
