Yesterday's Tractor Co. Trusted Parts Supplier since 1995
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
hard steering 1370
gary r schenck
10-28-2012 18:44:07
75.207.42.213
having trouble with 1370 case steering ,steering wheel tuff to turn even when moveing,took steering motor apart,was not in very good shape,put in a rebuilt one, wasnt much better.lifted front end off of the ground,thinking might be frozen bushings in front axle, no not that ethier.drained hydrolic oil put in new filters,took out charge pump checked forwear, looked good,took out rightside hyd pump, no seals blown out,no exesive wear in either 8gal or 20gal side of pump,took relief valve apart for steering motor,cleaned up put back together.when you turn the wheel full left to right an hold it, you can hear the relief valve open.for some reason it does seem to turn a little easyer when the motor is at lower rpms any ideas
[Reply]   [No Email]
Case Nutty 1660
10-29-2012 12:22:34
75.127.24.27
 Re: hard steering 1370 in reply to gary r schenck, 10-28-2012 18:44:07
if you find nothing from the guy's advise, thhe better steering at lower rpm could be the flow divider in the brake valve is dumping too much to the brakes or lube, one other thing I have seen on them is a piston gland may be floating in one cylinder(nut comes loose or threads strip) couple more things to think about cnt
[Reply]  [No Email]
Turbo
10-29-2012 10:47:33
166.147.120.24
Try lubing bearings in steering column in cab.
[Reply]  [No Email]
oldabe30
10-29-2012 05:37:37
64.130.141.239
On mine the A59979 pressure relief washer was broke, in the brake valve.
[Reply]  [No Email]
Agri King
10-29-2012 04:46:36
216.222.183.148
T a 3000 psi guage in at the steering cyls. What is the psi?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
