TractorLinks.com
Show Parts for Model:
Air ride cab on a 2390
unclesteve
10-28-2012 15:55:58
I am replacing the brake discs on one of our 2390s and after sawing off the bolt that holds the rubber bushing or as case calls it , shock absorber, I got to thinking. Since a new shock absorber is $50, why not replace it with an air bag like the cab of our Freightliner?
I think that I can replace both rear mounts with air bags. Hook in an equalizer valve and lines to a small 12 volt compressor. I have a small air tank I can hook in.
This might sound frivolous , but it is not. I ruptured 2 discs in my back in 2000 and had surgery to enable me to walk without a limp. 2 years ago I reruptured one of those discs. An MRI showed all my lumber discs are bulged and I now have arthritis in my hip and back. Currently I get about 3 epidural shots each year. Narcotic pain meds help me through most days. My doctors are working with me to hopefully keep me from having a fusion. I have lost 60 pounds, huge help.
unclesteve
10-28-2012 18:13:53
 Re: Air ride cab on a 2390 in reply to 10ptbk, 10-28-2012 15:55:58
Some important points everyone has brought up. I didn't think about the park.
I think that leaving the front mounts as is will keep the cab pretty much in place, much like the hinge on the front of the FL.
This tractor has a FL seat in it. It has no air in it as right now my feet just hit the floor. I need to either remove the under seat tool box or use a seat with a lower profile suspension. The seat is much better than the stock seat in the other 2390 we have.
I have a Case air ride seat in the 4490. It is a vast improvement over any other seat I have ridden in.
I was thinking about how much the FL ride was better than our International truck which has the air suspension but not air ride cab.
This is the seat I think I will try next. My parts guy at Case told me the Case seat is a Sears.
http://www.buytruckstuff.com/product.asp?selcategory=29&p_gpID=216
I appreciate all the input.
Jimmie D. Phelps
10-28-2012 17:25:10
 Re: Air ride cab on a 2390 in reply to unclesteve, 10-28-2012 15:55:58
Case sells a Air ride seat. I put one in my 2590 and have one in my 9230. Would do a better job than your idea.
Case Nutty 1660
10-28-2012 16:26:13
I understand you wanting it to ride better but one thing to think about, the Iso-mount is part of the roll-over protection I do not believe air bags would keep the cab solid enough to keep it from possibly seperating from the tractor in a complete rollover, the cab ROPS would stay intack it just might not be with the tractor just my thoughts cnt
case trader
10-28-2012 16:26:13
i have gave the same thing a lot of thought, you would have to change the park to a cable, and i suppose the steering lines would need to flex, the ones on the late model tractors are simple most use a coilover shock as seen in most race cars, you will probably need a stablizing rod to help keep the motion up an down not sideways the ones under pete and KW sleepers look perfect,if a person could get it air tight he wouldn't need a air source.
D-C-741
10-28-2012 16:22:35
I would be thinking about it Staying in PARK ! Being the Cab Height would be Changing with the Air Pressure ?
JW
10-28-2012 16:08:36
It could work as long as it doesn't stretch your control cables too far and get things out of wack
