Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Case DC4 carb freezing
[Return to Forum]
jvw1955
10-28-2012 09:06:27
199.96.208.190
We have a 1955 Case DC4 which is still used on a regular basis fr PTO work, raking etc. But it is getting very hard to use on colder days, as the pipe from the carb freezes shortly after starting. Any solution to this? It starts very easily, I don't even use a battery, just a couple of cranks.
[Reply]   [No Email]
rusty6
10-29-2012 12:44:29
142.165.85.159
 Re: Case DC4 carb freezing in reply to jvw1955, 10-28-2012 09:06:27
A DC4 that starts in winter? I can only dream about that. Mine won't start on the hottest day of summer if it pulled by another tractor. I call it my "pull start tractor". Carburetor icing is a problem on most of my gas engines but as stated by others, just shut down for a few minutes to let the engine heat up the intake manifold and that usually clears it up and keeps it ice free on my Cockshutt 40, IH Loadstar, Olds engined pickup truck, etc.
[Reply]  [No Email]
mEl
10-30-2012 12:14:06
71.241.104.74
 Re: Case DC4 carb freezing in reply to rusty6, 10-29-2012 12:44:29
On the farm we had a 39 DC with the 5505 hi comp head and M&W pop up pistons. It would not start even in its stock form on 6 V so I know exactly what you mean. We converted it to 12V and it was reliable at any temp. We would start it at -20 if needed with no problem. unless you are a purist who likes to sit and stare at his "correct" tractor that he cannot use I heartily recommend a 12 V conversion, a good rebuild on the starter to assure it's condition and if spark is an issue a good look at the mag/ dist. whichever the Case may be.
I've heard all the stuff about heavy cables and hi cranking amp 6 V batteries but I first drove that 39 when I was only big enough to hold the steering wheel standing on the floorboard while Dad and Mom threw bales on a wagon while I kept it straight down the rows, Dad did the hand clutch and told me to keep her straight. I'm goin on 68 now and still have it and I know pretty much what makes her tick.
If you're gonna use it, 12V it!
mEl
This post was edited by mEl at 12:14:32 10/30/12.
[Reply]  [No Email]
Moline_guy
10-29-2012 10:46:48
216.106.216.6
As far back as I can remember, my uncle had a license plate wired to the manifold above the carb to prevent this very thing, never seemed to bother with that on.
[Reply]  [No Email]
dcz3
10-29-2012 07:34:41
166.181.3.41
I have a DC that does the same thing when I use it for snow removal and yes I do run ethanol. I bunge cord a piece of cardboard on the carb side problem solved!
[Reply]  [No Email]
jvw1955
10-29-2012 22:43:40
199.96.208.190
 Re: Case DC4 carb freezing in reply to dcz3, 10-29-2012 07:34:41
Thanks for all the responses, I was thinking maybe the carb just needed adjusted, since it seems to be worse in recent years, but that may be the new blends of gas instead, as mentioned. I'll try the cardboard first, that seems like the easiest route.
[Reply]  [No Email]
pete 23
10-28-2012 19:13:19
74.32.238.2
Often times, if you shut the tractor down after it is warm and iced up, the heat from engine will thaw it out and keep manifold warm enough upon restart to not bother again until next cold start up. What some guys do, not necessarily on that model tractor but all same principle, is to build a stove around the muffler, hook a tube to it and run it into air cleaner intake. This brings dry, warm air in but no exhaust with it. Same thing cars did with the air intake on carbureted engines only they had a thermostatic control on air cleaner to by pass it when air temp was warmer.
[Reply]  [No Email]
Christopher Mikesell
10-28-2012 09:42:48
76.226.201.14
This is called carbrator icing. It happens on cold damp days when there is a lot of moisture in the air. The main reason that it happens is that the carbrator venturi increases the velocity of the air and drops the pressure to draw the fuel. This causes water to condense out of the air and freeze. This problem is exacerbated by the increaseing use of ethanol in fuel (especially during the winter months, and especially in southern california and the surrounding states). Ethanol has a much greater heat of vaporization than gasoline, so it sucks up a lot more heat as it vaporizes. The solution is to run the tractor at idle until the intake manifold warms up, to insulate the manifold so that it looses less heat to the outside air, or to run gasoline without ethanol. You could also take off the muffler and make an exhaust pipe that blows right onto the manifold above the carbrator. Carbrator icing is a common problem with piston engined aircaft when the conditions are right, and aircraft have a carb heat system for dealing with the problem.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
