Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 1070 dosnt want to run
[Return to Forum]
grandpajohn
10-27-2012 22:07:41
4.252.214.75
My 1070 I have been working with is acting up. I rebuilt the injection pump earlier in the year and it ran fine. Lately it seems that when it sits for a few days it doesnt want to start. I give it a shot of either and it fires right up and all seems fine. This past weekend It does not want to start it will run as long as I am giving it either but will not run. I removed the sediment bowl at the pump and fuel runs out at a very good pace. If I pump up the hand pump it will fire up and If I continue to pump it after Its running it will continue to run and sounds fine, but after a little bit it quits running again.
I am thinking its sucking air and loosing prime but when I remove the sediment bowl at the pump fuel runs freely. Does any one have any ideas where I should look?
Thanks
gramps
[Reply]   [No Email]
grandpajohn
10-28-2012 21:40:20
4.252.212.180
 Re: 1070 dosnt want to run in reply to grandpajohn, 10-27-2012 22:07:41
Thanks for all the replys. I think I have narrowed it down to the transfer pump. I have good flow to the tansfer pump. I have replaced the filters and bled them all out. When I remove the line from the transfer pump to the filter there is no fuel being pumped when the engine is running, but If I hand pump it then fuel comes out.
I will talk with the injection pump guy tomorrow, I really dont want to take the pump off if I dont have too.
thanks
gramps
PS I wanted to use it for my plow day but it just didnt want to co-operate so it sat at home and the other trators got to plow more.
[Reply]  [No Email]
dwag
10-28-2012 18:00:03
216.24.123.196
Return line tee at pump has a check valve which can cause your problem. This tee is available cheaper from your pump shop rather than OEM.
[Reply]  [No Email]
JW
10-28-2012 16:10:26
75.249.84.10
Sounds like transfer pump is bad.
[Reply]  [No Email]
cs.hess
10-28-2012 13:27:15
69.88.206.67
-Remove fuel line an make sure you have a full flow--let it run couple seconds. There is a pencil filter in fuel tank at outlet an after 50 so years there might be stuff in tank. If it slows remove it an clean or throw away. Screen will catch dirt anyway an filters will clean micro stuff from fuel
[Reply]  [No Email]
jon f mn
10-28-2012 05:49:31
70.196.130.40
I would check out the transfer pump as well. I've never run a 70 series that wouldn't prime right up once the filters were bled. If the filters had bad seals and the transfer pump was good you should get a leak when the tractor was running.
[Reply]  [No Email]
Case Nutty 1660
10-28-2012 02:09:10
75.127.24.27
the sediment bowl is the first place the fuel goes before the transfer pump, it is then pumped thru the first and second stage filters then to the injection pump, my guess is you have air/air leak at one of the filters, did you replace the filters at the time of the pump rebuild? did you get the rubber ring seal at the correct filter? and did you bleed air out of the filters completely? also did you leave the injector lines all loose at the injector set the throttle at full and crank engine till all air/air bubbles were out and you had a good stream of fuel flowing when cranking? then you tighten injector lines, these steps should purge any air you have trapped in the system, you can also do a further purge after tractor is running if it still sounds like it is missing a bit by cracking each line one at a time and make sure no air is still trapped, also it is a good idea to make sure you have the fuel shutoff cable set to aloow full fuel delivery and also check timimng to make sure you have it excactly on proper specs, sorry for the long post just hoping to make sure you have not missed some thing, one final thing is if you have any fuel leaking at all at a return line/connections it can allow air to renenter the syaytem after shutdown, I always like to replace every seal on the return when replacing injectors please let us know what you find cnt tom
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
