Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
2290 powershift
10-27-2012 20:14:05
Got the tractor together and running but still having some issues. The clutch (ok, inching pedal) is not working correctly and the Case manual, while good for take apart and put together, doesn't explain much. Sometimes it won't move ahead when the clutch is released, if you pull it into reverse, then go ahead it goes, and pulls strong - no slip. Also the clutch doesn't release completely when you step on it, the gears grind when you put it in gear, I suspect sticky valves in the powershift control but is there other things that could cause this??
