Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: splitting stands
Chuck Machinist
10-27-2012 11:15:23
I appreciate your concept Tom. All of the ideas that I see here are awsome!
D G Wells
10-27-2012 13:03:28
 Re: splitting stands in reply to Chuck Machinist, 10-27-2012 11:15:23
Chuck, Look up "Case LA tractor split" in this forum and you will see a simple rig that I did to split a Case LA. A piece of angle iron with casters welded to the bottom and nuts welded to the top. Plates with tubes on them bolted with the pan bolts to the block. All-threads with nuts and washers inside the tubes screwed into the nuts on the iron brings it all together. Then I connected it to the front axle with angle iron and a clamp to make it travel together. A jack under the tranny and split pins on the sides and it was ready to split; worked good.---Derrol in Texas---
Chuck Machinist
10-27-2012 13:43:10
 Re: splitting stands in reply to D G Wells, 10-27-2012 13:03:28
Derrol,Thanks! Ur right.If in doubt, Hit the archives! chuck
