Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: splitting stands
[Show Entire Topic]  [Return to Forum]
tomturkey
10-26-2012 14:16:56
216.81.211.253
Chuck: Look at the holes on the sides of transmission and work down from there. I built a u shaped framework and put castors on the bottom of the "U" This will let you roll the trans/diff back from the motor frt end assembly. Now the front end I built two small "A" frames and welded a tube steel between and bolted in to the holes on the underneath of the nose . Now you must find a way the support the rear end of the engine. I used a steel frame work with brackets to bolt up thru the pan connecting holes. That was a mistake as you must put new gaskets at the rear of the pan after having it split. Mine leakeked badly and I had to remove pan and put new gaskets on.Sorry for the long post but I could not find any pics of splitting stand that would work with the 400,so, fabed my own.tom
[Reply]   [No Email]
Chuck Machinist
10-27-2012 11:15:23
96.225.131.208
 Re: splitting stands in reply to tomturkey, 10-26-2012 14:16:56
I appreciate your concept Tom. All of the ideas that I see here are awsome!
[Reply]  [No Email]
D G Wells
10-27-2012 13:03:28
69.6.131.161
 Re: splitting stands in reply to Chuck Machinist, 10-27-2012 11:15:23
Chuck, Look up "Case LA tractor split" in this forum and you will see a simple rig that I did to split a Case LA. A piece of angle iron with casters welded to the bottom and nuts welded to the top. Plates with tubes on them bolted with the pan bolts to the block. All-threads with nuts and washers inside the tubes screwed into the nuts on the iron brings it all together. Then I connected it to the front axle with angle iron and a clamp to make it travel together. A jack under the tranny and split pins on the sides and it was ready to split; worked good.---Derrol in Texas---
[Reply]  [No Email]
Chuck Machinist
10-27-2012 13:43:10
96.225.131.208
 Re: splitting stands in reply to D G Wells, 10-27-2012 13:03:28
Derrol,Thanks!
Ur right.If in doubt, Hit the archives! chuck
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
