TractorLinks.com
Show Parts for Model:
Axle pivot pin bushing for VAC
George1048
10-25-2012 18:30:18
My early adjustable wide front pivot pin bushing on my VAC is in need of replacement. The part number is 06472-AB, which is NLA from Case. Does anyone have one for sale, or have the dimensions so I can make one?
jon f mn
10-25-2012 19:43:43
 Re: Axle pivot pin bushing for VAC in reply to George1048, 10-25-2012 18:30:18
I have some bushings left from when I did my 830 and 400. If you know the size I could check if I have any that size.
George1048
10-25-2012 21:19:12
 Re: Axle pivot pin bushing for VAC in reply to jon f mn, 10-25-2012 19:43:43
The pin measures 1.117" and doesn't appear to be worn too much, so I would think the ID of the bushing should be 1 1/8" or so. I don't know for sure because the old bushing in the axle is almost gone! There is a lot of slop around the pin! The length of the bushing is 1 1/4" - 1 1/2"
jon f mn
10-26-2012 20:36:31
 Re: Axle pivot pin bushing for VAC in reply to George1048, 10-25-2012 21:19:12
What's the od? think thats what I got, will check when I get home
George1048
10-26-2012 23:57:19
 Re: Axle pivot pin bushing for VAC in reply to jon f mn, 10-26-2012 20:36:31
I'm guessing the OD to be about 1 7/16". The hole in the axle is wallowed out badly and elongated vertically. I will probably have to ream it to get a round hole again, and as near as I can tell 1 7/16" will cover the vertical measurement. This axle must have been on a loader tractor. It isn't original to my tractor.
