Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 504 piston
[Return to Forum]
outsidersag
10-18-2012 15:02:36
75.245.155.229
Anyone know if the rod pin in a 504 piston is the same size as the 4 3/8 piston out of an 830 diesel?
[Reply]   [No Email]
dboll
10-19-2012 05:56:35
209.23.168.233
 Re: 504 piston in reply to outsidersag, 10-18-2012 15:02:36
what exactly are you planning on doing? I assume you have some 830 rods and pistons that you want to work with? A 504 piston will have a precup so unless you are building a direct injected dsl I would forget them
[Reply]  [No Email]
outsidersag
10-19-2012 10:32:47
75.234.161.70
 Re: 504 piston in reply to dboll, 10-19-2012 05:56:35
Its going to be a gas with a turbo. I have a set of good 830 diesel sleeves and pistons and rods i want to use just because i have them. This is going to be a clean out some of the parts in the shop project.
[Reply]  [No Email]
dboll
10-19-2012 05:39:17
209.23.168.233
contrary to the self appointed resident expert here the 830 diesel and the 451 both have a 1.4995 diameter pin so maybe someone can explain why you would need 1070 rods to get the wrist pin size that you already have, 20/2290 are both small pin pistons,a 22 has keystone rings, a 20 has straight cut rings, you building a gas or dsl.? gas rods would cut down your reciprocating weight a little and if you stroke it you can run bbc pistons, M farmall rods work good with a 2.5" journal and a piston with the right height would allow you to run a one piece rod instead of welded rods
[Reply]  [No Email]
jon f mn
10-19-2012 07:06:06
70.194.65.22
 Re: 504 piston in reply to dboll, 10-19-2012 05:39:17
Doug, doug, doug, You have so much anger and resentment. I'm worried that carrying around all that will lead to health problems. It's not uncommon for that kind of stress to lead to hyper tension, which can lead to ulsers, heart attacks, and even stroke. Maybe you could seek the help of a certified profesional to help you deal with these personal problems and put them behind you. I know I speak for everyone here at the case family when I say we all care deeply about you and only want what's best for you so you can continue to provide all the quality help and advice that you have in the past for many more years. Love ya man!!!
[Reply]  [No Email]
jon f mn
10-18-2012 16:02:02
70.197.193.25
If you want you can e-mail me, I'll walk you through a couple a problems you'll run into on a project like this.
[Reply]  [No Email]
jon f mn
10-18-2012 15:54:46
70.197.193.25
No, but you can change your rods for 1070/1170 rods then 2090 pistons will fit. Done that with a 930 years ago.
[Reply]  [No Email]
outsidersag
10-18-2012 16:02:54
75.245.155.229
 Re: 504 piston in reply to jon f mn, 10-18-2012 15:54:46
Im thinking about having a 400 block bored to take a 504 sleeve, not sure what piston and rod would work.
[Reply]  [No Email]
DKase
10-18-2012 18:16:24
75.102.180.184
 Re: 504 piston in reply to outsidersag, 10-18-2012 16:02:54
WOW!!!! That will be one HUGE hole!. Now 336 might be possible. LOL
[Reply]  [No Email]
outsidersag
10-18-2012 18:31:17
75.245.155.229
 Re: 504 piston in reply to DKase, 10-18-2012 18:16:24
I got a good set of 4 3/8 pistons and sleeves from an 830 but i just gota try 4 5/8!!!!
[Reply]  [No Email]
jon f mn
10-18-2012 21:29:25
70.194.66.248
 Re: 504 piston in reply to outsidersag, 10-18-2012 18:31:17
Do you realise that the 504 pistons are not flat top and require a head change as well? If the MM pistons have the same dimentions and are flat top they would be an easier change.
[Reply]  [No Email]
outsidersag
10-18-2012 16:02:40
75.245.155.229
[Reply]  [No Email]
jerry he
10-18-2012 18:44:10
74.34.74.174
 Re: 504 piston in reply to outsidersag, 10-18-2012 16:02:40
We bored an 830 gas block put in 504 sleeves used 830 rods with G1000 pistons. With a little other work got us a nice 336 puller.
[Reply]  [No Email]
outsidersag
10-18-2012 18:49:35
75.245.155.229
 Re: 504 piston in reply to jerry he, 10-18-2012 18:44:10
does the G1000 have the same size rod pin for the 830 rod or did you have to modify?
[Reply]  [No Email]
Don L.
10-19-2012 06:02:03
75.105.32.39
 Re: 504 piston in reply to outsidersag, 10-18-2012 18:49:35
I am thinking I have uesed 1000 MM pistons around here somewhere...
Don L.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
