Topic: jdmearis/LJD Inj pump question 530CK
[Return to Forum]
| Author |
[Modern View]
| TFLundyB275
10-16-2012 09:32:56
68.46.76.179
Hi, I'm trying to reach out to jdmearis/LJD and anyone else who can help. I have the injector pump off of my 530CK so I can refresh it up. I've looked through all of your posts, but getting some mixed up info so I want to clarify it with you so I can make one order for parts and be good to go.
First, I have the common symptom..runs for a few minutes, then loss of power until it dies. Takes few minutes to sit until it will start up again for the problem to reoccur. Continuous black smoke.
I am unsure why this is happening. You've stated before that this is due to the check ball in the return line fitting getting junked up. My fitting is clean, and DOES NOT have a check ball or spring. It is a regular pipe elbow. Is this standard on the 530 IP's...or is mine missing? Your parts guys did say that the regulator valve is not used on this pump. So what regulates the pressure then?
In addition, no particles in the timing window, but some very fine brownish debris under the top cover.
I am unsure the history on the tractor and the pump..it could very well have never been touched until now....or....someone has messed with it.
This is a list Ive put together from all your posts..Ive seen some varying part numbers, can you check if these numbers are correct for this pump? The guys you deal with for parts will not give me a parts list, etc...I'm forced to guess.
Also, is there any special tools needed for this pump? Seems the bristol wrench is not needed in these? Also, what are the part numbers for the top cover gasket and timing plate gaskets? Thanks.
Model: DBGFCC431 27AJ
RPM: 2100
SN: 508143
Mfg No: A35774
(1) Seal kit Stanadyne # 24371 - Spaco U24371
(1) Bronze bushing/ pilot tube Stanadyne # 16320 - Spaco U16320
(1) Metering valve #20849
(1) Complete Set of Fuel pump vanes and liner blade: kit- #11318 liner #16753
(1) Housing pressure regulator valve #15830 (not needed?)
(1) Plastic governor weight vibration dampener ring update- “EIC” #29111
(1) Plastic timing window for testing #13366
(1) Tool 13371 drive shaft seal installation tool |
| TFLundyB275
11-07-2012 08:47:05
68.46.76.179
Re: jdmearis/LJD Inj pump question 530CK in reply to Case Nutty 1660, 10-16-2012 09:32:56
| Alright George Ive sent you an email.
I've tried to contact USDiesel and get some parts and tools but they are not that willing to help me.
Do we have another source for parts and tools to rebuild these pumps? |
| george md
10-17-2012 21:44:19
209.213.167.201
Re: jdmearis/LJD Inj pump question 530CK in reply to TFLundyB275, 10-16-2012 09:32:56
| TF, Send me an email with a phone # and I'll call you . I have some pictures of the taking apart etc of those pumps. I keep most of the parts here and have a test stand to check them. george |
| Adirondack case guy
10-16-2012 14:49:22
74.69.160.79
| I suspect that JD is up on his property in the northern Adirondacks. If so he is "Off Grid" I haven't seen any posts from him since a few weeks ago when he was home here in Otsego Co NY. He was/is a very brilliant mechanic in the area, and does have a superior knowledge of injection pumps. That being said I guess that he will only answer you, if he decides to get on the YT website. Loren |
| TFLundyB275
10-16-2012 12:19:01
68.46.76.179
| Thanks for the reply George. I'm not sure whats going on so I'm open to suggestions.
The engine ran in the manner I described, with the tank pulled and cleaned, the supply line blown out, both filters changed out, and the pump intake screen cleaned.
I inspected the return line today, seemed fine.
While I have the pump out I just wanted to refresh it totally and not have to worry about it again.
I had asked the parts guy if that Spaco kit included the timing window gasket and top cover gasket but they could not confirm it....
You can fill me in with the timing marks and any calibrations. I have the JD manual that covers this pump but I have not done any work yet..its just on the bench waiting for me to get more info and parts in hand.
The only thing I did was set the engine TDC per the Case manual, verified it, scribed the IP to the mounting area, and pulled it off. |
| george md
10-16-2012 11:38:57
209.213.167.201
| TF, That Spaco kit will have all the gaskets that you need. If you are having trouble with it shutting down and do not have a regulator,my guess is that the return line is plugged or possibly the suction line and filters. Meter valves don't go bad often and measure the vanes before you condem them. If you install the newweight basket,do you know how to locate the new timimg mark? Plastic window is needed only to check the advance, if it is working and how much. george |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
