| Case Tractors Discussion Forum |
Topic: Case SC???????
[Return to Forum]
| Author |
[Modern View]
| Jon R. Young
10-14-2012 12:51:29
50.41.79.115
I have a Case SC I have been tryin to get runnin. It has been sittin quite a few years. I have cleaned the carburetor, all the ports are clear and there is gas gettin to it. The manifold is clean, the points are gettin spark and I believe the plugs and wires are hooked up right, the firin order is 1,3,4,2. Does anybody have any ideas of what could be wrong with it? I have tryed to pull start it multiple times and it will run for a few seconds with startin fluid but then it will just die as soon as it runs out fluid |
[Reply] [No Email] | |
| Fixerupper
10-14-2012 19:00:03
100.42.82.164
Re: Case SC??????? in reply to Jon R. Young, 10-14-2012 12:51:29
| | If the compression is way down it won't have enough intake suck to make the carb work. It will suck enough up to fire a little on ether. Went through that exasperation a year ago trying to get a low compressioned VAC running. If the compression is reasonably good, then there are fuel delivery problems somewhere. Seems like those Zenith carbs are real picky about a little dirt in the idle passages. Jim |
| vac400
10-14-2012 18:32:52
64.246.113.88
| Jon, First take a compression test or a leak down test to check your cylinders. If OK then take a known good spark plug ,hose clamp and add a piece off wire an ground the other end. Now crank it over an see if you have spark at the plug. If you do then you know you are getting fire to the plug. So now pull the carb. and remove the jets an take some torch tip cleaners and run them through the jets and holes if possible. Take carb cleaner an shot through the ports.If you can get it to run long enough take a propane torch no flame and run it close to the intake gasket to see if you have a problem, if the engine gains speed you have a bad gasket. I hope this helps. Jerry from Northern Ohio |
| Jon R. Young
10-14-2012 17:55:37
50.41.10.95
| I am located in Southern Ohio. I will keep y'all updated. |
| casenut1
10-14-2012 17:51:01
107.8.39.45
| Jon where are you located at. |
| Jon R. Young
10-14-2012 17:20:22
50.41.10.95
| Yes the needle is open 1 1/2 turns, the float is not stuck, and I am not sure about it gettin suction, I will have to check I will also take off the valve cover and see if anything is stuck or bent. Thanks for the help! |
| Case Nutty 1660
10-14-2012 17:25:53
75.127.24.27
Re: Case SC??????? in reply to Jon R. Young, 10-14-2012 17:20:22
| just my two cents but if she is sucking either in I am wondering if you still have a port blocked in the carburator I have had them drive me nuts before please give us a update on what you find cnt |
| Adirondack case guy
10-14-2012 14:51:31
74.69.160.79
| Pacience My Lad Pacience! If the tractor had set for an amount of time as you stated, chances are a valve or two were stuck. When you tirned it over by towing or what ever, you could have bent some push rods. Take the valve cover off and crank it over by hand, to check valve movement. If you have some valves stuck, you should not have much of a problem freeing them. The bent pushrods?? can sometimes be straightened, but they will fatigue in time, because you will never get them perfect. Don't give up on it so easily. You will like it when you have it running and be able to use it. Paint and cosmetics can come later. Loren |
| todd Hamilton
10-14-2012 14:22:21
174.252.189.117
| Make sure the float is not binding on the little axle in the Carb. Old zenith carbs are bad about that. Are you getting vacuum at the air intake on the Carb? If not with Carb off are you getting vacuum at the intake manifold? |
| j hikemper
10-14-2012 17:37:33
50.102.5.142
Re: Case SC??????? in reply to todd Hamilton, 10-14-2012 14:22:21
| check that carburator, but 1st , make sure that it has vacuum at the air filter ,, sc were infamous for burnigg thru exhaust and intake manifolds , therefore sharing gases , and when that happens it will not have much vaccume ,, if that is your problem .george md repairs them , also , i have a repaired one here that i could sell |
| casecollectorsc
10-14-2012 16:03:07
64.33.230.2
| Is the load needle open 1 1/2 turns? Pulled a DC for an hour one time, only to find out my nephew turned the load needle shut instead of turning off the gas at the tank! |
| Jon R. Young
10-14-2012 13:48:45
50.41.79.115
| I have replaced the sediment bowl and gas is comin out in a steady stream of the fuel line. I believe that Somethin is tore up in the head I will probably just sell it. Thanks for the suggestion though. |
| Bill Brackemyer
10-14-2012 13:21:34
173.19.30.117
| You say that you cleaned the carb, but did you clean the fuel line and the sediment bowl thoroughly as well? Those can varnish up as well. If it will run on starting fluid then it will run on gas. Make sure it is getting it. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
