Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 1958 310B Front Loader Valve
[Return to Forum]
RGV hay
10-12-2012 13:04:22
216.183.45.145
I have a Case front loader on a 1958 310B; the front loader ID plate reads Model Number 4032659, although I suspect that this may be the serial#. Its hydraulic pump is driven from the front of the engine. It has a Gresen Minneapolis FO, 2 spool loader valve with float. The bucket tipping spool has begun to bind up. I don't have the schematic or breakdown of this valve; therefore I need it or advice on how to disassemble the spool to check o-rings, springs or whatever may be binding.
[Reply]   [No Email]
DKase
10-12-2012 19:47:10
75.102.180.184
 Re: 1958 310B Front Loader Valve in reply to RGV hay, 10-12-2012 13:04:22
Take the caps off the front end of the spools to start with. (opposite end as the handle) There is a screw in there with washers and a spring, I have seen the screws loose, and broken springs that will cause what you explained. Simple fix if that is the problem.
[Reply]  [No Email]
RGV hay
10-13-2012 15:47:34
216.183.45.145
 Re: 1958 310B Front Loader Valve in reply to DKase, 10-12-2012 19:47:10
Turned out to be grunge in and around the spring, more than likely from the missing rubber caps on the spring end of both spools. Thanks for the insight!
[Reply]  [No Email]
RGV hay
10-13-2012 06:24:56
216.183.45.145
Thanks, I prefer simple. I'll post what's in there after the weekend.
[Reply]  [No Email]
RGV hay
10-12-2012 16:00:05
216.183.45.145
Thank you for the breakdown. It appears to be the same as the 420B except it is upside down on the 310B, mounting under a horizontal plate. Would you happen to have the parts list? Thanks again!
[Reply]  [No Email]
Case Nutty 1660
10-12-2012 16:12:49
75.127.24.27
 Re: 1958 310B Front Loader Valve in reply to RGV hay, 10-12-2012 16:00:05
here ya go cnt
[Reply]  [No Email]
RGV hay
10-13-2012 15:52:41
216.183.45.145
 Re: 1958 310B Front Loader Valve in reply to Case Nutty 1660, 10-12-2012 16:12:49
Thanks again; I went into the bucket tipping spool this afternoon and found grunge around the spring probably from the missing rubber caps which the pictorial brought to light. Works fine now, thanks!
[Reply]  [No Email]
Case Nutty 1660
10-12-2012 13:46:37
75.127.24.27
this is from a 420B parts but should be the same as it's little brother the 310B cnt
[Reply]  [No Email]
RGV hay
10-12-2012 16:05:23
216.183.45.145
 Re: 1958 310B Front Loader Valve in reply to Case Nutty 1660, 10-12-2012 13:46:37
Thank you for the reply; it appears to be the same as the 420B other than it is upside down on the 310B, attached to the underside of a horizontal plate. Would you happen to have the parts list? Thank you again!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
