| Case Tractors Discussion Forum |
Topic: case 600 problem
[Return to Forum]
| Author |
[Modern View]
| sww011
10-10-2012 07:56:35
75.106.0.53
I have rebuilt the engine had the injection pump rebuilt and the injectors checked. I have also cleaned the precumbustion chambers. the tractor will start and run on 3 to 4 cylinders and as it warms the other cylinders come in so the engine smooths out and runs ok. this process takes about 20 minutes every time you crank it. |
[Reply] [No Email] | |
| Roger S
10-11-2012 19:30:07
74.46.121.244
Re: case 600 problem in reply to sww011, 10-10-2012 07:56:35
| If you have cleaned the first stage fuel filter, and replaced the secondary and third stage fuel filters. Install an oil pressure gauge where the small line is by the secondary fuel filter. You should see 15-20 lbs pressure. If you do, my opinion is the injectors are eighter sticking, or have a poor spray pattern. As the motor warms up the injectors can free up, and or the fuel will ignite easier if they aren"t spraying correctly. It"s just my opinion. |
| zach81
10-10-2012 18:08:40
71.46.120.76
| I"m with John.....sounds like a valve job. Did you not have this done during overhaul? |
| zach81
10-10-2012 18:08:29
71.46.120.76
| sww011
10-12-2012 05:57:15
75.106.0.39
Re: case 600 problem in reply to zach81, 10-10-2012 18:08:29
| Ground seats and valves. |
| John Saeli
10-10-2012 14:35:26
66.66.16.240
| Tell us about the valve job. New seats & valves, or ground seats & valves. |
| 1031D
10-10-2012 08:03:57
107.8.250.69
| Sounds like bad injectors or low compression. If the fuel doesn't squirt into the power cell engine properly it won't superheat and ignite. Also, low compression can cause poor ignition and as it warms up the pistons swell and seal. |
| dirondack case guy
10-10-2012 14:22:48
74.69.160.79
Re: case 600 problem in reply to 1031D, 10-10-2012 08:03:57
| I agree that compression is the problem. I presume you replaced rings, or sleeves, pistons, you didn't say. I am also assuming that you stagered the rings around the pistons. If all this was done, I would hook it to a dyno and properly break in the engine under varying loads. We had problems with new tractors, sold in late fall and sentenced to manure spreader duty for the winter. If they didn't straighten out during spring tillage, we put them on the dyno, removed the aircleaner eliment and sucked borax off a table spoon into the engine. That deglazed the cylinders and seated the rings. Our Case Territory Service Rep. tought us this little trick. Loren |
| sww011
10-10-2012 17:26:24
64.202.238.156
Re: case 600 problem in reply to dirondack case guy, 10-10-2012 14:22:48
| I was thinking compression myself. I have just replaced pistons rings and sleeves. I also staggered the rings. My brother told me to hook it to a disk and work it good. thanks for the comments and suggestions. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
