Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Moisture gathering in the bowels!
[Return to Forum]
Chuck Machinist
10-08-2012 06:15:17
158.106.48.10
I think it would be an appropriate time for all of us to check the moisture levels in our herds,old and newer ..I.E. motors and trannys,and hydraulic systems, since there has been a lot of talk about it on the forum this year. Best of luck. Chuck
[Reply]   [No Email]
IA Roy
10-09-2012 23:14:58
67.142.172.25
 Re: Moisture gathering in the bowels! in reply to Chuck Machinist, 10-08-2012 06:15:17
I bought a DC from a friend had added antifreeze to the transmission. I didn't think about it, but it was too thin to keep from freezing. When I found out it was frozen. I waited till the temp got above freezing one day, and got it moving. I drove it down the road about a half mile and put it in the heated garage. I drained 5 or 6 gallons of slush out of it, and let it sit a day. No damage that I know of. My FIL had a Farmall M that froze and cracked the rear end housing. He had it welded or brazed to prevent lube from leaking.
[Reply]  [No Email]
tomturkey
10-08-2012 12:12:37
216.81.211.253
Oh yes a new fall ritual, just like maple trees in the spring, we tap tractors in the fall to let the water out. Hope all is well with Chuck and John. gobble
[Reply]  [No Email]
Pastor John
10-08-2012 14:22:04
208.126.65.204
 Re: Moisture gathering in the bowels! in reply to tomturkey, 10-08-2012 12:12:37
I'm thinking we can rewrite the operating manuals.
Anything to get little brother chattering!
[Reply]  [No Email]
Pastor John
10-08-2012 10:44:37
208.126.65.204
Just curious little brother better does moisture always seek the lowest level in the transmission or oil pan? Does the tractor need to sit for a period of time before you tap off the water?
Since the SC sits over the winter is it better to check for moisture in the fall or spring?
I had an experience with antifreeze (very small amount)when I changed the oil in the SC the first time. I was concerned initially but it never showed up again in following oil changes. I recall the previous owner telling me he pulled the head and ground the valves. I assume it was at that time some antifreeze found its way to the pan and the oil.
Going out to winterize the SC this afternoon. Gas treatment and antifreeze check.
[Reply]  [No Email]
Chuck Machinist
10-08-2012 18:06:16
96.225.131.208
 Re: Moisture gathering in the bowels! in reply to Pastor John, 10-08-2012 10:44:37
Couldn't get that archive story out of my head about the D in Indiana this past winter when the fellow couldnt move her, cause she had a block of frozen water in the transmission.and looking at all the early freeze conditions developing over the country I thought i would shake a coconut or two. doing well here ,two days of solid rain ,no complaints Chuck
[Reply]  [No Email]
jon f mn
10-08-2012 16:26:27
70.194.74.97
Water always settles to the bottom. It can settle out over night or take a few days depending on the oil. When you get water depends on how you use it and what the weather is like where you live. If you use the tractor hard for a day once in a while that will usually get it hot enough to get the water out. Water is more of a problem on tractors not used much because they don't get hot enough to cook it out. Here in Mn we get water over winter from the cold weather so I drain mine in the spring.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
