Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 1070 Hydraulic couplers
[Return to Forum]
Kow Farmer
10-05-2012 19:42:38
76.77.202.46
Hi everyone,
I have the "old" Case hydraulic couplers on my 1070 tractor. Well I went to move some machinery around and all my hydraulics on the field cultivator and disk are Pioneer couplers. I went to my neighbor and he gave me this part number for the "old" Case coupler adapters 4080-4. Sound correct? I went to town to get the "old" Case male end and Pioneer female adapters to be able to use my tillage equipment. Is this part number 4080-4 only available through Case? I found 4085-4 at the automotive store but the male end is too small to fit in my hydraulics on the tractor now and the female too small also to plug the hydraulic hoses into. Any help is greatly appreciated. I am going to look for new parts in the morning. Thank you all.
Kow Farmer (Kurt)
[Reply]   [No Email]
D-C-741
10-06-2012 20:42:54
24.59.187.41
 Re: 1070 Hydraulic couplers in reply to Kow Farmer, 10-05-2012 19:42:38
We change all of our tractors over to the ones used on the 90 Series .
[Reply]  [No Email]
Ron Sa
10-06-2012 10:26:47
75.106.112.105
Just went and looked. For my 1170, the adapters that I use got from NAPA 4080-4.
[Reply]  [No Email]
RGMartin
10-06-2012 08:27:10
98.21.111.48
After 35-40 years your hose are probably shot anyway, New hoses, Pioneer Push/Pull couplers, and weld up some brackets to use snap-rings.
[Reply]  [No Email]
John Saeli
10-06-2012 06:28:06
66.66.16.240
4080-4 are the correct couplers to couple the male pioneer ends to the Original Style CASE Female Couplers. What we do here is to carry the couplers in the tractors, in a plastic bag, to keep them clean. In the older tractors with CASE female couplers, we carry the 4080-4 adapters. In the newer tractors with the smaller pioneer female couplers, we carry the 4085-4 adapters.
[Reply]  [No Email]
j hikemper
10-06-2012 11:05:18
50.127.67.14
 Re: 1070 Hydraulic couplers in reply to John Saeli, 10-06-2012 06:28:06
What i have is a set of Old Case to Pioneer adapters for my 1070 , I need a set that does JD too one of my DCs came here sporting a JDeere hydro quik coupler off of a 3010 junker clunker . so , ,Around the farm most everything i have has one Deere and one Pioneer coupler, the deere is on the down side , pioneeer fastens to up side ,,this way i can always get it rite the 1st time , and i only need one adapter in each tractor tool box, because it is always half rite with the connectors
[Reply]  [No Email]
dzus
10-06-2012 06:14:28
97.73.64.150
Unless you have everything changed to the same ends these adapters are probably your best bet. We keep a set in the tool box of our 770 so we can hook to pioneer type hoses. Any farm supply store should have these adapters. Probably cheaper than Case-IH.
[Reply]  [No Email]
1370rod
10-06-2012 05:37:05
184.158.59.35
Kurt, I have 2 sets of adapters, one set says CASE with no part no. and one is Pioneer 4080-4 as you mentioned earlier. They look identical as if made by the same manufactor with stamped names being the only difference. Rod.
[Reply]  [No Email]
tractor300
10-06-2012 05:07:23
74.36.180.147
I just made my own adapters. Take a Case male end and attach a short pipe nipple and then a female Pioneer end and your set to go. Was really no cost for me as I had all the pieces I needed on hand anyway.
[Reply]  [No Email]
1370rod
10-05-2012 20:22:26
184.158.59.35
Hi Kurt, all my 70 series had the old style CASE couplers when I acquired them. I have since changed all the female ends to the late style universal pioneer type. I do not know the part no. as I can go to the local dealer tell them what I need and they set the stuff on the counter. A parts book for the latest 1070 will list the items. Your tractor would more than likely need the adaptor fittings installed on the hose ends to accept the coupler. It's a little more work than just useing adapters but given the choice I would never go back. Give it some thought, if you need part no. I can look them up for you. Rod.
[Reply]  [No Email]
Kow Farmer
10-05-2012 20:38:16
76.77.202.46
 Re: 1070 Hydraulic couplers in reply to 1370rod, 10-05-2012 20:22:26
Hi Rod,
I am just trying to figure out what is the best way as far as $ for hydraulics. Do I just buy the old style male tips for my equipment or get the adapters that fit into my current couplers on the tractor? Decisions...Decisions...LOL
Kow Farmer
(Kurt)
[Reply]  [No Email]
dboll
10-07-2012 06:25:53
209.23.168.213
 Re: 1070 Hydraulic couplers in reply to Kow Farmer, 10-05-2012 20:38:16
I would convert it to iso/Pioneer couplers. The less things that hydraulic oil has to pass by the better. Dad's 970 had Case couplers and everything had Pioneer, what a pita. Get the couplers that you push in to couple. If you buy another piece of machinery or a cylinder chances are that it will have Pioneer couplers. Save your Case couplers as they are in demand for restoraions.
[Reply]  [No Email]
1370rod
10-05-2012 20:54:23
184.158.59.35
If you only have a couple items that you will be useing, the adapters are probably the most bang for the buck. If you put the old style couplers on your implements that will hinder using a different tractor should the need arise. I have some adapters in the shop , I will check in the morn and see if they have part no. on them, Rod.
[Reply]  [No Email]
jon f mn
10-06-2012 03:19:11
166.248.77.227
 Re: 1070 Hydraulic couplers in reply to 1370rod, 10-05-2012 20:54:23
We used those adaptors on the farm for our 730 and dc's. THEY ARE A REAL PAIN!!!! Definately change to pioneer on the tractor if being original is less of a concern for you that having something that is easy to use. It will be money well spent.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
