michael27brown
New User
I have a 1958 Case 800 COM. What is the right fluid to fill the transmission? I was thinking hy-tran but keep thinking ring and pinion diffs. in automobiles get gear oil. would there be a problem with filling the trans. with 75w-90? Also, does anyone elses COM grind when shifting into gear? It seems to be better when warmed up. Would DEXRON 3 help this? Reverse seems to not grind at all. And once in say fourth gear you can shift between third and fourth slick as a button. But going back to second an first it wants to grind. When it grinds and slides into gear the tractor kinda jumps forward just a hair but it doesnt try to creep before releasing clutch.
