930CK '64 wheel tread widening?
AKAnanuk
New User
Hi
Can the wheels be reversed to give a wider stance/tread on the "64 930CK"s?
Just by looking at the parts manual, and the tractor itself, it looks doable.
I"d like to get a little more distance between the rears to straddle the hay windrow better.
thanks in advance!
Use rim mounted duals, take off the inside tire and you have a wide stance. BUT be prepared to break axles as it will do that over and over again. From 500 to 930 six speed , if dualed it will break axles.
