| Case Tractors Discussion Forum |
Topic: 300 round nose ?
[Return to Forum]
| Author |
[Modern View]
| 311
09-24-2012 19:16:00
208.79.1.238
I need an engine for my 300. Will a VAC engine have enough power for the tractor or should I find an original 148 to replace it with? Has anyone put a VAC engine in a 300? Mine is a 2 bolt starter. Thanks for any input. |
| Joe Young
09-25-2012 06:53:31
75.92.245.199
Re: 300 round nose ? in reply to 311, 09-24-2012 19:16:00
| | 311 It depends on what you want to accomplish. If you have an 124 CI VAC engine, and all you are looking for is a show/parade tractor, that may be an inexpensive path. Others have indicated it will bolt right up, but I have never been that lucky. There always seems to be a gotcha of some sort that elevates the cost to something close to what it would have cost to fix what I had to begin with. It also creates a problem if you ever want to sell. Mis-match tractor/engine combinations usually don't sell as well as one which is matched up correctly. If you want to maintain the utility and hp of the 300.... The 148 ci engine with thrust washers and 2 bolt starter was/is a very common engine. If in your shoes, I would look for a good running engine, or a donor block and rebuild what you have. - Joe |
| JPFL
09-25-2012 05:42:39
173.65.222.172
| FYI, I have a block from a 211b, I am not sure but was told it is a 148. Thanks Jim 813--------- |
| TimBinWV
09-25-2012 04:15:32
24.112.195.84
| The 124 cu. inch VAC engine will fit, but the tractor will be underpowered. The 124 doesn't turn as many rpm's as the 148, either. (Pretty sure about that, as I've been told that here) The block from a 200 series (126 cu. inch) is, however, the same as a 148. The sleeves/pistons will fit from a 148 into it. If at all possible, find a 148. What is wrong with the 148 you have? |
| eldo case
09-25-2012 06:59:15
70.195.0.34
Re: 300 round nose ? in reply to TimBinWV, 09-25-2012 04:15:32
| The bottom of the 126 would have to be bored out for the 148 sleeves to fit. |
| TimBinWV
09-25-2012 14:27:58
24.112.195.84
Re: 300 round nose ? in reply to eldo case, 09-25-2012 06:59:15
| Thanks for the info, Eldo. That part wasn't related in the info I'd been told. |
| 311
09-25-2012 05:21:31
208.79.1.238
| The #2 rod came loose and went through the block. Trashed the piston/rod/block and I assume liner. The crank looks good. Thanks for the info. |
| eldo case
09-25-2012 07:01:41
70.195.0.34
Re: 300 round nose ? in reply to 311, 09-25-2012 05:21:31
| Done one like that. I welded up the hole in the block and had crank turned replaced rod and you know what you have. |
| JohnDY
09-25-2012 05:30:24
99.160.136.233
| The 350 Round Nose hp was boosted up to 42. Not sure what block they used to accomplish it but someone might chime in that knows. |
| Joe Young
09-25-2012 06:40:05
75.92.245.199
Re: 300 round nose ? in reply to JohnDY, 09-25-2012 05:30:24
| | John A 164 ci dry sleeve engine was used to get the additional HP. Those engines are a bit hard to find and parts are getting scarce/expensive. The engine was only used for 3 years before it was abandoned and replaced with the 159 ci engine in 530 or 188 ci engine in the 630. - Joe |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
