Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
4890 P/S pressures
John Saeli
09-17-2012 05:43:26
On our 4890, I checked the pressure at the valve in the back that feeds the Power Shift. I get 192# - 195# warm, @ idle, all 3 ranges. Don't have a manual telling me if that is the correct pressure. She slips some, under load in all 3 ranges. Suspect the Torque limiter. Anybody got pressure spec's?
1370rod
09-17-2012 08:28:55
 Re: 4890 P/S pressures in reply to John Saeli, 09-17-2012 05:43:26
John, I don't have a manual for a 4890, but I believe all powershift tractor run the same flow divider pressure something like 185-205 psi. Your pressures sounds good to me. That idea of limiter slippage is a real possibility. Rod.
casecollectorsc
09-17-2012 07:04:24
Is there a demand for 4890 parts? Can get one that had a cab fire 10 years ago, and still sitting there. Engine is locked up because the back valve cover was partly melted and let water in the engine. Thought we would take the 2470 and pipe hitch And hook hoses from 24's remotes to steering cylinders and pull home.
Case Nutty 1660
09-17-2012 15:34:17
 Re: 4890 P/S pressures in reply to casecollectorsc, 09-17-2012 07:04:24
I towed a 2670 to my shop that way worked great except how fast the remotes will make it steer, it will go full left to right in a few seconds lol
