Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 731 Starter hook up
[Return to Forum]
Les Oakes
09-13-2012 16:10:12
72.29.247.253
I have a Case 731 Comfort King. There was not a starter on it when I acquired it and now I don t seem to be able to get it wired properly. There are two large studs on the solenoid and two small studs. My problem is that I seem to have only three connections. One from the positive side of the battery, another that has a round connector to go on one of the large studs and a 14 gauge wire to go on one of the small studs. I think there should be one more as I can t get the starter to engine. Any diagram or help would be great, thanks
[Reply]   [No Email]
Gordon Oakes
09-13-2012 20:25:43
64.56.133.146
 Re: 731 Starter hook up in reply to Les Oakes, 09-13-2012 16:10:12
I have the battery cable and the smaller wire with the large terminal on the top post. I also hve the one small cable on the small post which is marked S. iS THIS CORRECT.
[Reply]  [No Email]
mEl
09-14-2012 04:06:10
96.249.141.58
 Re: 731 Starter hook up in reply to Gordon Oakes, 09-13-2012 20:25:43
that sounds right to me, the S should be the start terminal and the other should have a I next to it denoting ignition.
[Reply]  [No Email]
jon f mn
09-13-2012 16:28:05
70.193.67.48
The top stud is for hot wire from bat. bottom goes to starter post and the small wire goes to one of the others, I can't remember which, but only one will work. The other small one is unused.
[Reply]  [No Email]
mEl
09-13-2012 18:26:16
96.249.141.58
 Re: 731 Starter hook up in reply to jon f mn, 09-13-2012 16:28:05
The battery cable goes on the large copper stud that is not connected to the starter post as does the smaller wire with a large loop terminal. the other goes on the small post nearest the block. The smaller wire with the large loop feeds the dash and the starter button and ignition switch. Nothing else goes on the other copper stud that the terminal that comes from inside the starter and fastens to the solenoid stud. If a Delco gas starter, the outer terminal with the small nut a wire would go from there to a resistor if the tractor is so equipped and I believe that the 30 series gassers were from the factory. the purpose of that terminal is to bypass the resistor on starts only to feed 12V direct to the coil
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
