Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: case 1170 crankshaft pully removal?
[Return to Forum]
aaron m moore
09-02-2012 15:10:35
24.13.121.188
so the crankshaft pully on my 1170 went bad. the rubber liner went bad to be exact. i have a new one an i took out the bult. i'm trying to use a gear puller to remove it but there isnt any thing the gear puller will clamp onto with out slipping off. any one have any ideas.
thanks
[Reply]   [No Email]
Agri King
09-04-2012 04:32:56
216.222.183.148
 Re: case 1170 crankshaft pully removal? in reply to aaron m moore, 09-02-2012 15:10:35
You shouldn't pull on the outside of the balencer. Sometimes they can come off hard but....Take the bolt out of the crank and remove the washer, screw the bolt back in, run a 3/8 tap ALL the way in, in 2 bolt holes across from each other. Use a T bar puller and 3/8 bolts, make sure the bolts are bottomed out in the balencer.
[Reply]  [No Email]
farmboyWI
09-02-2012 18:36:55
50.105.144.29
Not sure if the pulley is the same as my 1370 but I had to build this contraption to get mine off using a hydraulic bottle jack. Threading bolts into the pulley to put a puller on (like the book says) only resulted in popping the threads out. I hope the pics are clear enough and make sense. The “frame” is built from channel iron and some strap steel. I made it as two halves to slip behind and around the pulley with the outside of the pulley sitting in the channel iron. The two halves are bolted together using the notched steel on the outside. Then put a deep socket between the crankshaft and the jack base and the ram against the stack of washers the chains are welded to. Mine still came off hard with a 10 ton jack! Hope this helps.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
