Topic: 801-B questions
[Return to Forum]
| Author |
[Modern View]
| dkeav
09-01-2012 11:57:42
50.104.212.155
Looking at an 801-B, tractor is in decent shape with the usual problems. Wanting to know what i'm looking at getting into on fixing the trans, current problem is can only go into 3 or 4th. That is all I have right now, I'm wonder if it is a trans problem or if it would more likely be a case-o-matic problem. If it is the case-o-matic what kind of ballpark would i be looking at for worst case scenerio.
The tractor runs well, but the pump loses prime if it sets for a week or two, rotary pump. The experience with these pumps so far has been, its going to need a rebuild and it is going to cost about $1000-1200. Question, if i'm going to spend that money on the the pump, could an inline pump be put on there instead? |
| dkeav
09-02-2012 13:57:47
50.104.212.155
Re: 801-B questions in reply to dkeav, 09-01-2012 11:57:42
| Sounds good guys, thanks for the tips. I will research what I would be getting into on rebuilding the transmission, and probably shoot the guy an offer. Thanks again. |
| John Saeli
09-02-2012 15:31:45
66.66.16.240
Re: 801-B questions in reply to dkeav, 09-02-2012 13:57:47
| The tranny is bullet-proof. Something needs attention with the shifter mechanism on top. |
| Bret4207
09-02-2012 14:46:00
64.19.90.196
| You might not have to rebuild the tranny, it might be a simple problem like a pin out of place or something. |
| John Saeli
09-01-2012 19:07:18
66.66.16.240
| I agree w/ Jim, the problem is with the shifter mechanism in the 8sp. Nothing to do w/ the converter. As for the fuel problem, sounds like fuel is leaking through the transfer pump. I would guess that the crankcase oil is being diluted w/ diesel. Very easy & cheap fix. The seals are less than $10.00 & easy to replace. The transfer pump is mounted to the side of the big pump & easily removed for servicing. |
| j hikemper
09-01-2012 19:15:49
50.102.31.72
Re: 801-B questions in reply to John Saeli, 09-01-2012 19:07:18
| hi john ,finally catchin up around here,, i want to fix my pump American /bosch , the seal is behind the 4 bolt sheild shaped governor plate ?rite? ,, maybe i should call you whenever is best .. |
| j hikemper
09-01-2012 18:54:46
50.102.31.72
| i am surprized no one gave you advice , yet , if you only have 3rd or 4th , that is a standard manual shifter problem that has nothin to do with the c-o-m clutch ,in theory a 730 dry clutch would bolt to the front of the standard tranny , you may not understand the shifter , it is upstairs /downstairs double neutral you can learn alot from the archives , there are 15 yrs worth of wisdom ,,, also ,, if the fuel pump loses prim e it is possible that fuel will get in the oil , ,, i am told this is a simple fix that can be done with the pump in place,but have not taken time to repair , my 800 also0 loses prime and leaks fuel into the oil for yrs . i simply turn off the fuel tank valve when not running ,, |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
