| Author |
[Modern View]
| Case Nutty 1660
08-30-2012 18:18:23
75.127.24.27
      had fire here today that burned 450 acres on me and my neighbor, I jumped on the 1470 with the offset disec and helped put it out, I was in such a hurry I did not take the camera with me for shots while I was working in it, the flames where as high as the hood on the 1470 most times some times higher, the fire department could not do any thing but watch me as I put up a fire guard and also was throw dirt right in the fire putting it almost out at times she jumped my guard at burned a bit more but we managed to keep it down to 436 acres and only about 35 on me after me and the 1470 had it about 80% contained the one mines blade came through and widened my guard, it was great to see them!! the Sherrif boys are thinking it was a arson set fire as there was three different ones with in a couple miles and no sign of a flat tire or any other obivous ignition point cnt |
[Reply] [No Email] | |
| wilson ind
08-31-2012 05:47:22
70.239.85.115
Re: what I did this afternoon in reply to Case Nutty 1660, 08-30-2012 18:18:23
| Happy to know your ok as well as equipment. Really happy fire did not get close to my former home as well as that old parts tractor sitting in your way for last 4 years. Glad to know you and tom railsback as some of my best friends. |
| vac400
08-31-2012 05:30:18
64.246.113.88
| Tom, I am glad you and the equipment are fine. We had Cheryl's parie burnt this spring had flames 30 feet high ,it was a controled burn. Jerry |
| Doc Larry
08-31-2012 04:42:27
216.146.101.227
| I had a lightning strike in May on my place with about the same result. It hit in the CRP which was thick and very dry from all the rain last year, and took off before the neighbor and I could get it. The VFD folks got here very fast, as did two neighbors with their discs. Between all that and a county road, it only burned about 100 acres. Fortunately, the wind was blowing away from the house. The power company had to come out and replace a bunch of poles the next day, but that was the only real damage. That was in May. It is so much drier now after a spring and summer of almost no rain. I'm west of Billings, about as dry down where you are I think. |
| McKerrow630
08-31-2012 02:41:21
50.105.81.43
| Holy smokes!!!! wow Tom, Thank the lord for YOUR quick thinking!! Don't know much about "wild fires" but have seen there distruction.Gla all is well. I promise you a e-mail tonight (daughter should have it fixed) one more thing I would like to see a pic of the hometown "CASE FIRE FIGHTEN TRACTOR AND IT'S DRIVER! I to agree with the "forum case guys" about your actions. God Bless |
| Straw Boss
08-30-2012 21:36:43
74.221.167.226
| Why couldn't the fire dept help? Our Vol dept has a 1 ton pickup and a tanker truck with a nozzle mounted right on the front bumper. Just drive along side a grass fire and direct the nozzle from inside the cab. I thought everybody had them in your dry grassland country. Sure glad no Case machinery (or people)were harmed in the making of those pictures. |
| Case Nutty 1660
08-31-2012 00:37:17
75.127.24.27
Re: what I did this afternoon in reply to Straw Boss, 08-30-2012 21:36:43
| Brad, yes they have the nozzle that will spray as you drive but this fire was so fast and hot it would not have done much with the amount of sage brush that was burning, remember the flames were 10-18 feet high a 15mph plus wind, they would not have had enough water to last more than a few minutes putting out enough water to do any good I have fought fires here like this many times, only way to stop them is to remove their source of fuel water works great for mop up and wetting down around a building ect, when it is this dry and 100 degrees a fire unit spraying water does about as much good a P-ing on it, the wall of fire we had they call a fire storm it creats its own wind I sure wish I could have taken pics, this burnt ground does not even begin to show what that fire looked like at the time, I am hoping that some pics will be in our local paper if so I will post them, I am just thankful nothing that can't be replaced was lost, it was a very bad fire but could have been much worse |
| straw boss
08-31-2012 20:13:47
198.228.201.153
Re: what I did this afternoon in reply to Case Nutty 1660, 08-31-2012 00:37:17
| I gotcha. Two years ago, early spring, the train threw sparks as it traveled through the area. Started a fire every two miles or so for about twenty miles. Kept all the vol. Dept.s busy for awhile. More fires at once than trucks to chase em. Between farmers disking and the mounted squirt guns, we managed to corral the flames but any kind of stiff wind might have been a different story. |
| j hikemper
08-30-2012 20:30:12
50.102.92.34
| CNT , You Are A GREAT AMERICAN,,and rest assured , though ,You can Bet , all of us on HERE ,who would find ourselves in that situation would had done the same thing ,, That Is why this is STILL a Great Country ,and I feel BLESSED to have found a great bunch of guys that make a difference ....... HANG TUF ,Jim |
| casenut1
08-30-2012 19:34:36
107.8.39.45
| good job there Nutty.i know what you mean about hard to put out.i was first on the seen of a fire in a corn field. had already been shelled and dry fodder was everywhere.all i had was an aluminum grain shovel, the fire got to within 60 yards of his house. sure was glad to see the fire department show up. |
| TimBinWV
08-30-2012 19:32:38
24.112.195.84
| Great Job, CNT. Woulda loved to have seen ya in action. |
| Kow Farmer
08-30-2012 18:36:18
76.77.202.46
| CNT, I hope you and the 1470 and disk or OK. If this was arson, I hope that the poor SOB's get caught and fined for their stupidity. Is any of this land your hay or small grain fields or your neighbor's. Sorry about the language. But I don't have time for people that are disrespectful or extremely careless around other people's property, especially in this year's drought situation. I hope the best for all farmers affected. Good luck. Kow Farmer |
| Case Nutty 1660
08-30-2012 18:46:28
75.127.24.27
Re: what I did this afternoon in reply to Kow Farmer, 08-30-2012 18:36:18
| luckily all it burned on me was pasture but about 250 on my neighbor was his winter pasture/ hay fields that he had left due to the drought, as to the 1470 and disc I hope I have not done any axle damage to the disc as I was in some very rough country with it and was in 6 th gear haulin butt to stay ahead of the fire, I did get it stopped about 150 yards before it got to my hay fields that I am going to be turning cows into in a week, am very glad I was able to sdtop it when I did |
| Bill talbert
08-30-2012 18:28:57
174.255.2.111
| That is a great thing you did!!!! Firefighters are doing everything they can!!! Too many wild fires burning out of control!!!!!! We all can help out the firemen and women!!!! |
| Case Nutty 1660
08-30-2012 18:40:41
75.127.24.27
Re: what I did this afternoon in reply to Bill talbert, 08-30-2012 18:28:57
| you are so right Bill, they really had no choice but to watch and they had several engines protecting my neighbors house, the abandoned farm less than 1/4 mile north of him is a total loss it really was a team effort i am just so glad to have been able to get to it as soon as I did as I would guess I saved another 800-1000 acres from burning and by then it would have been close to a subdivision about a mile from where I was able to stop it thank GOD cnt |
| soundguy
08-30-2012 18:27:27
107.41.3.146
| | OH MY hope all is ok! |
| Dutchman
08-30-2012 18:26:44
69.66.113.248
| It's a good thing you have a tractor ready to go a a drop of the hat .... was there a wind to keep it moving ?? grass fires move FAST with a little wind ... don't even ask HOW I know that ... lol ... another story ... To bad you didn't have the camera ... but nice pictures of the after matter .. Did your tractor get any burn marks ??? mark |
| Case Nutty 1660
08-30-2012 18:35:07
75.127.24.27
Re: what I did this afternoon in reply to Dutchman, 08-30-2012 18:26:44
| Mark no burn marks but let me just say I was within 3 feet of the flames and had the offset in it when I could and yes there was wind about 15mph with bigger gusts to and it was creating it own wind to sounded like a tornado beside the tractor and the heat was so bad I was afraid it might crack the windows, I had them open as I have no a/c and I can not believe how dang hot it was, when I first was trying to put up the first guard the wind and the fires own wind was moving the fire at a very fast rate it traveled 250 feet in less than a minute |
| j hikemper
08-31-2012 11:17:33
50.102.92.34
Re: what I did this afternoon/MOTOR SOUND in reply to Case Nutty 1660, 08-30-2012 18:35:07
| YES,, That Was a HOT WILD one ... JUST Wondering ?,.Could you Tell anything like this was going on CNT ??,,while stirrin small hot burning brush piles with the front loader ,i noticed ,the motor ingests the hot air and makes a different somwhat faster smoother sound ,, don'tknow if it was overly detrimental , but that was always my que to back away from the HOT kitchen |
| Case Nutty 1660
08-31-2012 14:47:23
75.127.24.27
Re: what I did this afternoon/MOTOR SOUND in reply to j hikemper, 08-31-2012 11:17:33
| yes the 1470 motor was changing sounds at times, now whether that was due to less oxygen or the higher temps I can't say as I was not watching the pyro and the disc was placing a larger than normal load on it due to sixth and seventh gear and running in tough sod to boot cnt |
| JT's RandR
08-30-2012 18:24:30
208.124.87.199
| Glad to hear that you managed to put it out and with minimal damage. |
