188D fuel delivery rate?
gusbratz
rebuilding my roosa master db pump on my 1962 530 triple range tractor. it's going pretty good, the distance between the plunger rollers measures 1.950 with air pressure being pushing the plungers outward. is this the correct delivery rate? the book i'm useing is an IH blue ribbon manual for a TD6 with the same pump so the measurement and drive dirction is different in the manual. thanks.
