Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Head Studs on CASE Crawler
[Return to Forum]
Herm00
08-29-2012 18:59:34
75.168.104.216
Im am putting my Crawler back together this weekend. While removing the head, I wrecked a few head studs. I was wondering if I could use bolts instead of studs? Or is that not recomended?
[Reply]   [No Email]
george md
08-30-2012 20:57:59
209.213.167.201
 Re: Head Studs on CASE Crawler in reply to Herm00, 08-29-2012 18:59:34
Which length do you need , I have a massey
block I can take somw out of.
Call me.
george
[Reply]  [No Email]
Christopher Mikesell
08-29-2012 20:29:09
76.226.202.92
Yes, you can use bolts, BUT, you can expect some problems. First, your replacement bolts must be strong enough to take the torque. Also, they need to have the right thread. Length can also be a problem since the original studs usually thread all of the way into the block, and it will be hard to do this when trying to torque (and re-torque after running) a bolt. Also, threading them in only a little bit will not cut it. The holes will probably break out. You need 1.5-times-the-nominal-diameter of depth for full holding power. The holes are not usually threaded deeper than 2-times the diameter, so you only have a small ammount of adjustment to get it right. Also, studs ususally have a coarse thread on the end that threads into the block and a fine thread for the nuts. This makes them easy to torque, since you torque them by turning the fine-threaded nut.
As a result, you will have to go to a specialty fastener supplier to get ones that will be strong enough, have the right thread, and be the correct length. You will then need to do some fooling around with thin washers to get the bolts to thread in at the right depth. The bolts will then be a pain to torque, and your bolts might bottom out when you re-torque the head after running. Thus, in my opinion, you would be better off buying studs than messing around with bolts.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
