| Author |
[Modern View]
| zeek
08-26-2012 17:38:31
71.48.143.132
anyone know how to put a 5.9 cummins in a 1030 or 1070 thanks |
| RGMartin
09-04-2012 07:03:54
98.21.110.67
Re: 1030 cummins conversion in reply to zeek, 08-26-2012 17:38:31
| Quoting Removed, click Modern View to see
Exactly what case hoe used a 6BT? 4BT sure. |
| 1031D
09-04-2012 07:12:05
107.8.250.69
Re: 1030 cummins conversion in reply to RGMartin, 09-04-2012 07:03:54
That's kinda what I was wondering too |
| RGMartin
08-29-2012 09:51:03
75.88.137.201
Re: 1030 cummins conversion in reply to jd_adict, 08-26-2012 17:38:31
Giving up almost 100 cubic inches isn't exactly a step in the right direction.
The writers of the rules clearly were clearing into a particular color or two??? |
| mEl
08-27-2012 04:36:10
108.10.131.69
| I don't think any similarity exists between the 1030 tranny case and the later tractor's bell housing mentioned, anything is possible tho, I think that a friend of Doug Boll has done this but not sure how it was done, maybe he'll pop in and add to this discussion. mEl |
| JW
08-26-2012 18:47:15
75.207.56.74
| Your best bet is going to be a 1070. Then MAYBE you can use the bell housing and flywheel out of a 2096. My big question is why? |
| zeek
08-28-2012 14:42:50
71.48.143.132
Re: 1030 cummins conversion in reply to JW, 08-26-2012 18:47:15
| class limit is 466 cu in think ill get more hp with the 5.9 over the 451 |
| 1031D
09-03-2012 20:53:40
107.8.250.69
Re: 1030 cummins conversion in reply to zeek, 08-28-2012 14:42:50
Horsepower don't mean squat, torque is everything, and replacing a long stroke tractor engine with a light stroke truck engine is a bad idea. There is no replacement for displacement! |
| 320B
09-03-2012 23:29:15
70.29.89.242
Re: 1030 cummins conversion in reply to 1031D, 09-03-2012 20:53:40
You may not be aware that the 5.9 cummins is a tractor motor and was used in quite a few different pieces of case equipment including there back hoes before it went into a pickup.It also produces twice as much torque as horsepower. |
| oldtanker
09-04-2012 06:51:49
66.228.255.239
Re: 1030 cummins conversion in reply to 320B, 09-03-2012 23:29:15
Don't get all excited about that Cummins so fast. About 3 years ago a friends son was serving in Astan. The kid emailed me asking if I would do a little internet looking at diesel pickups (his dad is computer dumb). Both Ford and GM plainly listed the graphs with all the info on HP and torque on the engines while Chrysler did not. It took a couple of days to get the info. The advertised HP and Torque for the Cummins was achieved about 300 RPMs OVER THE GOVERNED MAX RPM! Think about it and tell me how in the heck, with EPA rules, can you make almost the same HP and torque going from 5.9L (360CI) to a 6.7L (408CI) or 6.6L (402CI) and still be EPA compliant????? As long as Chrysler can show that they got those HP and torque numbers during testing it isn't consider false advertising. The fact that you can't get the stock engine to run the RPMs needed to produce those numbers makes it misleading.
Rick |
| 320B
09-03-2012 16:55:28
70.29.89.242
| A p pumped 12valve cummins will get you about 300 hp with no internal engine mods,I'd go with a cummins. |
| case1175
09-03-2012 16:47:11
166.182.3.201
| Like was said above giving up 100 cubes is not really a good idea, and I dont know that its easy to get a 5.9 up to 466. I know many people have decubed the 8.3 for 466 classes with good success. Dont know what class your running but the only problem with case motors is they lack in head flow, all of which can be cured. |
| case1175
09-03-2012 16:49:30
166.182.3.135
Re: 1030 cummins conversion in reply to case1175, 09-03-2012 16:47:11
| Forgot to mention, obviously you would want a 70 series 451 and not the old powercell motor if you stuck with case motor. |
