| Case Tractors Discussion Forum |
Topic: Case wont start.
[Return to Forum]
| Author |
[Modern View]
| Kansas Kirk,
08-22-2012 18:10:07
205.245.110.20
this Case 2670 wont start or even turn over, good cables and good batteries, but still nothing. |
| Jim in Sask
08-22-2012 20:33:37
24.72.132.70
Re: Case wont start. in reply to Kansas Kirk,, 08-22-2012 18:10:07
| I had a 4490 that did that once, replaced the "intermediate starter solenoid". If I remember correctly it was mounted about midway up on the side of the engine block. Dealer said they frequently needed replacing. Don't know if the 70 series had this second solenoid or not. Another possibility could be a failed neutral safety switch, I had to replace one on a David Brown I have. |
| Joe (Wa)
08-22-2012 20:25:52
67.142.175.20
| You can jump the solenoid but as c.hess said it can be dangerous if you"re not familiar with that kinda thing. I do it with regular gloves and the handle end of pliers. You just got to know when to hold them and when to fold them. The safest way, disconnect the cables at the battery post. If neg gnd system, connect cable from battery pos directly to the terminal on the starter. Connect a cable to negative post on battery and just touch the other end to a clean ground on the tractor frame away from the gas tank or other possible flammable (you will probably get an initial contact spark). If the starter motor turns, the problem is in the solenoid or upstream in the ignition circuit.You already know the solenoid terminal is not correct so why not just replace it. Solenoids are relativity cheap, not worth the time to take apart and clean the contacts unless it unavailable. Joe |
| c.hess
08-23-2012 08:09:35
69.88.206.67
Re: Case wont start. in reply to Joe (Wa), 08-22-2012 20:25:52
| AGREE with new solenoid since Kirk cant get nut off. Guess have to cut nut or break bakeliteto hold it. Again remove n battery cable first as your woorking in a very confined place on that tractor an if it started its pretty heavy if it runs over you!!! |
| c.hess
08-22-2012 18:37:03
69.88.206.67
| Take solenoid apart an clean an renew inside.Just be careful an puush small screw back as you remove bakelite front. Its only screw that is fast to coil at rear.Theres a way to see if that is problem nut thats dangerous an i wont tell that.Do remove negative cable on battery before doing repair. . |
| Kansas Kirk.
08-22-2012 19:07:03
205.245.110.20
Re: Case wont start. in reply to c.hess, 08-22-2012 18:37:03
| Hi C,hess bolt holding battery cable on front end of selenoid turns then goes tight again, cant get cable off to get selenoid off. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
