Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 430 case slippage
[Return to Forum]
DerrickG
08-21-2012 09:12:58
74.82.68.160
Case 430 deisel. When purchased would slip in higher gears but worked fine in lower gears. Now won't hardly move in low gear and recently the eagle hitch will only go up slowly even with no load. Help!!
[Reply]   [No Email]
BarryfromIA
08-21-2012 19:18:12
67.55.176.78
Re: 430 case slippage in reply to DerrickG, 08-21-2012 09:12:58
Check the clutch housing for oil dripping out. Hydraulic oil should be clean, engine oil should match the dipstick. The seals on the pump drive can leak and cause the clutch to slip.
  [Reply]  [No Email]
Joe Young
08-21-2012 11:38:26
64.126.67.179
Sounds like one of your two clutches not holding. Adjust the hand clutch first. It should take 65 lbs of pressure to engage the hand clutch. It should snap over center when engaged. If that doesn't solve the problem, you'll need to split the tractor to access the main clutch.
Have you checked the hydraulic fluid level in the torque tube? I doubt the two issues are interrelated.
  [Reply]  [No Email]
Adirondack case guy
08-21-2012 16:17:31
67.246.153.242
Re: 430 case slippage in reply to Joe Young, 08-21-2012 11:38:26
Joe has hit it spot on . Adjust the hand clutch first, more than likely your problem, and then If that doesn't cure the problem , the master clutch on the engine flywheel, would be the problem.
Loren
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
